carpet replacement
Discussion in 'Saleen' started by mrvids, Nov 21, 2007.
  1. mrvids New Member
    Dec 7, 2004
    Message Count:
    42
    I am going to ask Santa for carpet for my 97 Saleen for Christmas, his two helpers offer molded and unmolded carpet. The elf that offers the non-molded has a better reputation (according to a coworker who has had his Buick worked on by both elves)and tells me I won't be able to tell the difference. The price is about $50 more from the elf installing the molded carpet. The original carpet is gray, if I've been bad this year I guess it'll be charcoal.
  2. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    If it were me ( and this kid has installed carpet a million times ) I would have Santa just drop off the direct replacement pre molded carpet and do it myself. It's a super easy job and enjoyable because you can't mess it up.
    Then use the "labor" money you were going to pay the elves and buy yourself a nice Saleen diff cover or some new plugs and plug wires.
  3. mrvids New Member
    Dec 7, 2004
    Message Count:
    42
    I tried to do a carpet change in a '92 Mustang convertible, and while I didn't have trouble getting it put in correctly, it was all the trim parts that gave me trouble.
    Things such as getting the "trees" lined up to hold the kick panels in place. But the 97 looks much easier. Is it? It looks like the sill panels and kick panels are pressed into place so I'd need to remove the console and seats is all, correct?
  4. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    Yes,
    The SN95 cars are a little easier as the center console comes out cleaner and the door sills as well. Just be wary of the knock off and not OEM replacement carpet as sometimes its a little smaller in the cut and you run into the problems you described before with the door sills.
  5. bigwingsaleen New Member
    Apr 11, 2005
    Message Count:
    67
    I would send a note to the FORD Santa and see if he might have a OEM carpet set o the shelf before buying a aftermarket set...especially from the ACC elfs.
  6. 88-378 Member
    Aug 11, 2007
    Message Count:
    626
    Go for it. I just did mine. Not too bad. I did trim a little more than needed between the pass seat and console, but luckily you can't see it. Seat bezel covers it and I put another little piece to hide it.
  7. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    Listen to Gary.
    Buy the factory stuff. I believe it already has the correct holes also.
    If the elves are short on cash and you go aftermarket, just set the new carpet right over the factory piece and cut away. It's so easy.
  8. 88FoxSaleen Founding Member
    Oct 29, 2002
    Message Count:
    364
    i want to put a new gray carpet in my 88. there are no stains, rips or damage to my original carpet though. can it be steam cleaned?
  9. 88-378 Member
    Aug 11, 2007
    Message Count:
    626
    Yeah you can. Just make sure you get a hold of a good machine that can suck the water back out and then dry it with a fan and maybe a heater.
  10. 2000xp8 Advanced Member
    Aug 9, 2003
    Message Count:
    4,466
    68
    I am under the impression that the ones from ACC carpets are a damn close to factory match, with fairly easy install.
    I haven't done it yet, but $100 for a molded carpet seems like a great deal.
    I've been in cars with them, but never have inquired about the ease of the install.
  11. FASN8N New Member
    Nov 17, 2004
    Message Count:
    518
    I installed ACC carpet in my 89 vert, no problems, perfect match. As with any project, take your time and do it right.
  12. mrvids New Member
    Dec 7, 2004
    Message Count:
    42
    How did you get the holes in the carpet where the pins hold the kick panels in place? I couldn't get them lined up quite right.
  13. FASN8N New Member
    Nov 17, 2004
    Message Count:
    518
    I dont recall having any problems with that part. If it doesn't work for you then time to modify the fitment!
  14. 89SSC18 Member
    Aug 3, 2006
    Message Count:
    361
    18
    I replaced the carpet in my '88 vert and my SSC about 4 yrs ago with the ACC sets. I don't remember having any problems with fitment. It went in real smooth in both cars and looks like the original. The biggest challenge I had was getting the rear seat bottom snapped back down in the vert.
    good Luck
Share This Page
