cLEANING eNGINE bAY
Discussion in '94-95 Talk' started by Guero, Dec 18, 2005.
  1. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    Whats the the best stuff to clean your engine with?
  2. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,237
    66
    Syracuse, NY
    simple green and either a steam cleaner or pressure washer
  3. stprorolla49 Active Member
    Oct 9, 2004
    Message Count:
    1,447
    36
    Fairfield, CT/North Jersey
    a lotta people like to use simple green....i just took an old armor-all spray bottle or something like that and filled it like 1/4 way with car soap, and the rest with warm water...then closed it and shook it for a while to make a VERY concentrated solution....i found that this took off a LOT of **** that was hard to clean.....
  4. sade04 New Member
    Sep 13, 2004
    Message Count:
    97
    Lansdale, PA
    engine degreaser works well
  5. RFMustangGT Member
    Apr 4, 2005
    Message Count:
    296
    Knoxville,TN
    if you use a steam cleaner be very careful. someone did that to mine when I bought it and water got into the distributor and killed the bearing in it. it also sure didn't help the idle pulley either as it went south about the same time.
  6. 1105 I AM the random post master...bow down
    May 3, 2003
    Message Count:
    3,882
    Daytona Bch, FL
    Steam cleaners are very bad to use, infact I've heard from sountless amounts of people that you should not use a steam cleaner for the reason listed above, and the steam will mess up some electronics.
    Just spraying and hosing it off with simple green wont work, and neither will a pressure washer alone. Sure the pressure washer will get the dirt off, but if its oily/greasy then you'll have to scrub it with a degreaser. No easy way around it
  7. wytstang Advanced Member
    Mar 14, 2004
    Message Count:
    5,154
    76
    Summerville,SC missing South Fl. weather :(
    Gunks "engine bright" or http://www.autogeek.net/pbapc32.html
    I loved it so much I purchased a gallon of it (All purpose cleaner). I have a concentrated bottle for the engine, and an 6:1 mix for cleaning my dash, carpet, and upolstry(sp?).
  8. Blackened302 New Member
    Jul 21, 2005
    Message Count:
    1,477
    McAllen, South TX
    definately +1!!! that **** works awesome!!
  9. 5.0_GT_kid Active Member
    Apr 18, 2004
    Message Count:
    1,709
    36
    Largo, Florida
    That link is for a Poorboys product.
  10. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    since there was no degreasers at my house, i just did the same. It worked pretty dam good. and i didn't even have to worry bout it getting on the paint.im always scared its gonna **** up the paint.
  11. stprorolla49 Active Member
    Oct 9, 2004
    Message Count:
    1,447
    36
    exactly!!! i use it on the apint sometimes too:D
  12. wytstang Advanced Member
    Mar 14, 2004
    Message Count:
    5,154
    76
    That is correct Poorboys world APC (all purpose cleaner). Cleanes your tires, engine, dash, seats (leather and cloth), and carpet. All you have to is dilute it to meet your needs.
Share This Page
