clutch cable help
Discussion in '94-04 V6 Mustang' started by dastang2, Jan 21, 2004.
  1. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    how do you get the clutch cable back on the clutch fork. it is too stiff for me to do it with my hands.
  2. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Have you tried having someone depress the clutch?
    Try some pliers to pull it over the fork?
  3. 98v6mustang Founding Member
    Aug 21, 2002
    Message Count:
    313
    take a long screwdriver or something to pry with and stick it behind the clutch fork (towards the rear of the car) and pry the clutch fork to put the cable on or you can just have someone in the car depress the clutch to relieve the tension
  4. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    i had somebody push the clutch in then i put a big socket behind the fork and i got the cable out. now i need it in. so i can pry it using a wrench or something. do you think the bellhousing will withstand the pressure
  5. 98v6mustang Founding Member
    Aug 21, 2002
    Message Count:
    313
    yes the bellhousing can take the pressure..
    just put a long screwdriver/pry bar and pry the clutch fork (in the same direction as the clutch cable would pull on the clutch fork)
  6. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    ok i got it on and it was not as hard as i thought. now i only need to bolt the exhaust on and the shifter down and slip the driveshaft in.
Share This Page
