Hey
Need a bit of help. I have just installed a quicktime bell housing with the 157 tooth fly wheel and all the goods. Now my clutch cable is acting up. When I push in the clutch is does not let me put it in to gear. I worked fine for about two weeks and then just stopped.I got a new cable and when I try to adjust it, I pull out on the cable and my clutch pedal flies up and hit the underside of my dash. When I get the pedal back down where it should be the cable is loose again. Anyone have any ideas or know of anyone that has change over to the Fox body clutch set up.
thanks, Jansen
thanks, Jansen
