clutch problem
Discussion in '2.3L (N/A & Turbo)' started by 79'293stang, Jan 2, 2006.
  1. 79'293stang Active Member
    Jan 6, 2003
    Message Count:
    486
    28
    Cedar Rapids, Iowa
    Well yesterday i was driving down the highway and went for a turn so i pushed in the clutch pedal and heard a clunk and the pedal went to the floor and had no pressure at all. So i limped it home figuring the clutch cable was culprit.
    I almost got home when all the sudden i heard another clunk and then i had pedal pressure again but it wouldnt let the clutch engage fully so it was slipping really bad so i got it home. I crawled under it and the cable looks just fine. Is my clutch bad or what would cause this i really dont know but i have to get it fixed soon... Thanks for any replys.
  2. samickguy15 New Member
    Sep 1, 2005
    Message Count:
    403
    Delavan, IL
    To me it sounds like you might have something funky going on with your clutch itself. The other possibility is, at least on my car ('93 2.3 5-speed), there is a self adjuster on the clutch quadrant. That would make a popping sound if it broke, came loose, etc.
  3. 79'293stang Active Member
    Jan 6, 2003
    Message Count:
    486
    28
    Cedar Rapids, Iowa
    Before it went out when i would push the clutch in at the bottom of the travel i would feel a little clunk for the last few days.
  4. Turbo_Raccoon New Member
    May 28, 2005
    Message Count:
    14
    Del Rio TX
    My clutch had the same problem but I put in a new clutch, pressure plate, and a thowout bearing and all the noises stopped. So I had no clue what had happened.
Share This Page
