Cobra Ignition
Discussion in 'SVT Forum' started by Maxboost50, May 24, 2004.
  1. Maxboost50 Founding Member
    May 8, 2002
    Message Count:
    302
    Louisiana
    What is the difference between the 96-98, and 03 ignition systems? Could the 03 system work on the 98, say to clean up the engine bay?
  2. Maxboost50 Founding Member
    May 8, 2002
    Message Count:
    302
    Louisiana
  3. djtech Founding Member
    Oct 17, 2002
    Message Count:
    372
    Metro Detroit
    There are many differences. The biggest one I can think of is that the 03 has coil on plug (COP) and the 96-98 series has twin coil packs for each side.
  4. Maxboost50 Founding Member
    May 8, 2002
    Message Count:
    302
    Louisiana
    I figured that, but what would it take to swap to the 98 motor? Different valve covers? Engine wiring harness? BTW, Thanks for the reply.
  5. djtech Founding Member
    Oct 17, 2002
    Message Count:
    372
    Metro Detroit
    Hmm, I'm sure you'd need the items you've asked about. You may also need the newer heads to support COP; I'm not sure. I have not seen the 98 motor up close and personal. I have seen a lot of my 99 which is very similar to the 03 (and exactly like the 01).
    You would also need a new ECU which makes things complicated.
  6. Maxboost50 Founding Member
    May 8, 2002
    Message Count:
    302
    Louisiana
    Probably not worth it. Thanks Djtech.
  7. djtech Founding Member
    Oct 17, 2002
    Message Count:
    372
    Metro Detroit
    Agreed. I thought that right off the bat, glad you came to the same conclusion :)
  8. SWTMUSTANGMAN Founding Member
    Jun 11, 2002
    Message Count:
    97
    Austin, Texas
    COP should work on any mod motor, the only thing that wouldn't cross over is the coil covers. If you look closely they have different bolt locations, 96-98 on four corners and 99+ has them two across from one another. Hope this helps. Valve covers shouldn't matter....SHOULDn't being the key word!
Share This Page
