CODE P0401 HELP!!
raul.ruiz
Hi guys!
I need help with my stang, i own a 2002 mustang V6 manual trans with flowmaster dual exhaust. The SES light is on, so i came to autozone and they read the code P0401, i read that is a common fault in our cars and most of the time is the DPFE sensor, is that correct? is there something that you would recommend to check/clean before buying any parts?I would also like to know where to buy parts if necesary.
I would appreciate any advice.
Raul R.
code 0401
I went to autozone and bought the EGR sensor and the service engine soon is not there yet, about 150 miles since I replace it. I think that was the problem, I feel smother the engine on steady velocity and more miles per galon.
Maybe this can help someone with same problem.
yeah i replaced the egr sensor and replace the egr valve itself as well but i did notice that a low idle it sounds like air is escaping from the passenger side i think they might not tighten everything down right. its like a low ticking sound
"ticking" is a good indication of an exhaust leak. Check all connections and let us know!:nice:
