Common Cobra Problem?
Discussion in 'SVT Forum' started by varad, Jan 12, 2008.
  1. varad New Member
    May 15, 2006
    Message Count:
    26
    Philadelphia
    I was looking into a 1997 SVT Cobra from a dealership. However, the dealer's mechanic told me that there is a ticking from the heads. He said that this has to do with the camshaft housing/mount clearance and that is a common problem on this motor. Is this true and is it an easy fix?
    Thanks
  2. cobranator Founding Member
    Sep 16, 2001
    Message Count:
    90
    Kelowna, B.C. Canada
    The tick is not a particular problem to the 96-98 Cobras although it may happen, it was more prevalent on the early 03 Cobras and the problem was the valve guides IIRC.
    If this 97 you're looking at has a tick it may be the hydraulic lash adjuster that's making itself known and relatively easy to change, I doubt it would be the camshaft housing/mount clearance.
  3. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,529
    318
    133
    Don't matter, had bacon.
    My 96 has the tick too and I always just assumed it was valve guides, how do you check and fix/replace the hydraulic lash adjuster. Where is it?
  4. cobranator Founding Member
    Sep 16, 2001
    Message Count:
    90
    The lash adjusters are essentially like lifters although they don't move up and down in the DOHC Cobra engines as they do in the pushrod engines.. They sit stationary in their own bores with one end of the cam follower/rocker arm sitting on top of them and the other on the valve tip. If you'll pull the cam cover you'll easily see them.
    As how to diagnose which lash adjuster is collapsed and making a tick use a mechanics stethoscope to localize the source and maybe change those where you think the tick is the greatest. Or if funds allow change all of them. Now I've never changed any of them but people that have said it wasn't all that difficult.
  5. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,529
    318
    133
    Thats great to know, I thought I had to buy new heads:nonono: You say its easy and I am mechanicaly inclined, but to replace the lash adjuster wouldnt I have to remove the cam girdle and then the cam itself to get to them. Also where do I buy them from, and any idea on cost?
  6. cobranator Founding Member
    Sep 16, 2001
    Message Count:
    90
    You can get the lash adjusters from Ford but I don't know how much they cost, ask in the parts department. But before you go and replace them make sure that in fact that's your problem. No you don't have to remove tha cam girdles, the cams stay in place. As I've said I' ve never replaced them, others have, I would suggest get a shop manual and read up on the procedure. I have Haynes manual and the instructions are pretty clear as how to do it. You'll also need a Ford valve spring compressor tool...(Ford tool no. T93P-6565-A).. to push down on the valve spring retainer to relieve the pressure from the cam follower. Once the cam follower is removed you can pull out the lash adjuster.
  7. blackfang Founding Member
    Dec 17, 2001
    Message Count:
    1,539
    Richmond, Va
    Ask him how many 96-98 DOHC's he has worked on to know this is a common issue?
  8. varad New Member
    May 15, 2006
    Message Count:
    26
    Philadelphia
    he said he contacted his local ford dealer and they told him it was a common problem.
  9. blackfang Founding Member
    Dec 17, 2001
    Message Count:
    1,539
    Richmond, Va
    Wow you would think after 11 years there would be atleast 1 TSB for technicians to reference for this "common problem". Yet, there isn't a single one. I find that very odd.
    There is a TSB(03-11-4) for the 03's for a left hand side ticking that was due to valve guide wear for vehicles built before 11/1/2002. I think the Technician is confused.
  10. LaserSVT Formerly known as *Zap* ImaSammich
    Jun 19, 2007
    Message Count:
    11,529
    318
    133
    Wait Im confused :scratch: The mechanic at the dealership called another dealer to find out about it?
  11. blackfang Founding Member
    Dec 17, 2001
    Message Count:
    1,539
    Richmond, Va
    Sounds about right. I get mechanics from small car lots that sell cars call me in regards to their Subaru they are selling/fixing. Most of the time they have no clue about the car. It is possible.
    However in this case it appears the someone was mistaken because there isn't a single TSB on that noise for a 97 Cobra. If it was a common problem, it would have been published years ago. There was one for early model 03 Cobras for that noise and it was known that same year those cars came out.
Share This Page
