hey all. I have an 01 gt auto that i am going to eventually convert over to 5 or 6 spd. I think i am staying na. I have 4.10s, accufab tb and plenum, cai, kn,bassani or x, bassani after, underdrive pulleys. I wanna get cams done, any good suggestions? i wanna be streetable, but i want nice performance and that bad ass sound. What do you make of these? what else do i need and how much will install run? any help would be appreciated. thanks
COMP CAMS FORD MUSTANG 4.6L & 5.4L SOHC MODULAR PERF2
Comp Cams XE Series
Comp Cams Ford 4.6L & 5.4L SOHC Modular Xtreme Energy Camshaft *1999-UP Performance Improvement Heads.
These cams feature radically new computer designed Xtreme Energy lobe profiles, engineered specifically for the Ford modular engine family. The cam profiles offer faster valve openings and more area under the curve to help promote a broad torque and horsepower RPM band. The modular Xtreme Energy cams are the most aggressive of all the engine families, which is made possible due to the unique design of the valve train of this engine. This unique valve train design allowed Comp's cam design engineers to push the limits on valve train acceleration rates while still maintaining everyday driving reliability. The cams are ground on new steel billet cam cores designed by the Comp Cams engineering team. This unique design offers an Xtremely stable valve train when used with Comp Cams Part # 26113 valve springs.
SOHC-Hot street cam, needs 3.55+ gears. +2000 stall. Needs intake, exhaust and computer PCM upgrade. Noticeable idle. 1800rpm to 5800rpm
XE270-AH Dur @.050 234-238 | Lift .550-.550 | LSA 113 | RPM Range 1800-5800
Applications: 1999-Present Ford Mustang 4.6L & 5.4L SOHC *Performance Improvement Heads.
PART# CCA-102600 'PERF 2'
Comp Cams XE Series
