Coolant Temp Sensor removed?!?!?!
Discussion in '2.3L (N/A & Turbo)' started by mightypoof, Jul 10, 2004.
  1. mightypoof Founding Member
    Mar 15, 2002
    Message Count:
    523
    Heres the story.... I put a water temp gauge in my pod so i just replaced the factory coolant temp switch with the sender for the gauge. The problem is that the factory sensor also helps to control A/F. What do I need to do? There must be a way to add a coolant temp gauge and I guess I did it the wrong way? Anybody got help?
    -TG
    PS-It runs pretty rich and that is probably the reason....
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Did you take the coolant sensor out of the lower intake manifold? If so, you removed the wrong one. The sender for the factory gauge is on the side of the block a little ways below the lower intake, THAT's what you need to remove to install the sender for your gauge.
  3. Ray III New Member
    Feb 10, 2004
    Message Count:
    604
    If you intend to have both gauges functional you can install a T fitting and have both on one port
  4. Ray III New Member
    Feb 10, 2004
    Message Count:
    604
    oh and I'm wondering, where is the knock sensor? There's a sender in the back of the side of the head for oil pressure and, near that, one in the back of the side of the block for coolant temp right?
  5. mightypoof Founding Member
    Mar 15, 2002
    Message Count:
    523
    oh ok....i gotcha....I thought they both ran off the same sensor?...
Share This Page
