Cooling system
Discussion in '2.3L (N/A & Turbo)' started by QangMartoq, Feb 28, 2004.
  1. QangMartoq New Member
    Feb 28, 2004
    Message Count:
    46
    I have an '87 LX Convertible, 2.3 w/A4LD auto trans (Yeah, I know, I really want a 2.3T and a 5-spd.. LOL)
    When I bought it, the cooling fan did not run. I ran the heater to keep it cool. I unplugged and replugged the connector on the motor, no change.
    A couple days ago, I was wondering if Ford duplicated what they had done in my former '96 Ford Windstar minivan - That is, make the cooling fan come on whenever an A/C mode was selected - Max A/C. Norm, Mix, & Defrost.
    It did, and I now switch between Vent and Defrost positions, however - I don't want to put any undue stress on my A/C system (Which is in working order), so what do I need to check to get the cooling fan running correctly?
    Thanks...
  2. latroca1 New Member
    May 1, 2003
    Message Count:
    234
    There is a relay box under the dash I know there was a post awhile back about that controls the fan when the sending unit reaches like 180 degrees i believe.
    I had the same problem and got me a fan from a taurus and wired a switch up with a relay and just turn it on when i know shes going to run hot!!!
    Works out pretty good as long as i don't forget about it!!!LoL........
  3. ssjmaverick23 Member
    Oct 29, 2003
    Message Count:
    222
    my fan just runs as long as the key is turned on
  4. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,751
    78
    do you have any idea how many amps the fan draws?
Share This Page
