Crap , crap, crap, crap......
Discussion in '2.3L (N/A & Turbo)' started by pixie, Feb 27, 2004.
  1. pixie New Member
    Dec 17, 2003
    Message Count:
    17
    Ames, Iowa
    I attempted to change my ignition module on my 92 2.3....I got the other one on and hooked up, but the car wouldn't start...So, I put the old one back on (the car started fine with it before I began the swap)...now it won't start with that one either!!!! I'm in hell, can anyone help!
    Carrie :shrug:
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Did you put any of the white paste on the back of it before installing it?
    Stinger
  3. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    did you make sure you put it in the right direction. If i recall, both plugs are the same and it CAN be hooked up backwards. Not sure if that would hurt anything though. Also you should reset the computer with the new module attached and see if that helps (reset by unhooking battery for 30+ mins) Getting any check engine lights?
    Dr.
  4. pixie New Member
    Dec 17, 2003
    Message Count:
    17
    Ames, Iowa
    White paste is on...and the thing is in the right direction (the little UP sticker on it helps :) ).....the only thing different between when it started and not, is that two of the mounting bolts broke off...one is out a ways, but one is broke off close to the mounting block...I bought new bolts for it, but I won't be able to do anything with them until the morning...If that will make any difference at all....I also checked all the fuses, and they're all good...
    Carrie
  5. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    AH, i dont know for sure the the bolts may help ground the unit to the car. it may not function if its not properly bolted on becuase it may not have a proper ground.
    Dr.
  6. pixie New Member
    Dec 17, 2003
    Message Count:
    17
    Ames, Iowa
    That's what I've been wondering....may have to get all creative, as I do not have a tap and die set.....
    Carrie
  7. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,498
    78
    Morgantown, WV...where couches meet their doom
    Doncha just love cars sometimes?
  8. pixie New Member
    Dec 17, 2003
    Message Count:
    17
    Ames, Iowa
    A hose clamp and a dremel....all good....
    :cheers:
    Carrie
  9. Slugstang New Member
    Dec 9, 2003
    Message Count:
    88
    Va.
    I got an extra dis if you want it. Still has a good modual on it. You pay the shipping it's yours.
    Mike
Share This Page
