deck/lights not turing on help~!
Discussion in 'Mustang Sound & Shine All' started by halfwaytie, Apr 4, 2009.
  1. halfwaytie New Member
    Jan 7, 2009
    Message Count:
    37
    alright i don't know if this is the right place or not but here i go. so my reading light never worked till two days a ago for like 2 mins. so i was looking at it and it just turned off. then i pushed it back up and pulled it down and it worked again but it turned off again but this time my deck and int light want with it! i though it was just my fuse so i did not worry but when i want to find and change it there where know fuses blown. so what could it be??
  2. 2BADSTANGS New Member
    Jun 19, 2008
    Message Count:
    398
    What year 'stang is it? I'm gonna take a stab in the dark and gues that it is an older fox body with the aimable map light. I would pull the light down and check the connections behind it. The switches in those lights are notoriously crap, wiggle it and see if the light comes on. As for the rest of the problems, all of them going out at once makes me think fuse. Use a test light or meter and test the fuse, I've seen some that look good, but are in fact bad.
  3. Supradude26 New Member
    Oct 12, 2005
    Message Count:
    86
    Sounds to me like by you moving the light around, being that it is old and didn't work before caused a short in the curcuit and blew a fuse. All the lights that you are having problems with are on the same curcuit so a bad fuse would really be just about the only option, unless all te lights are wired in series, going through the map light first. If by moving it around you broke one of the wires it could cause the rest to quit without blowing a fuse, but it is very unlikely. Get a 12 volt test light and check the wires and all the fuses. I think there is a fuse box under the hood which is probably where the fuse is for the light.
Share This Page
