Detailing Trunk?
Discussion in 'Classic Mustangs' started by wickedmach1, Feb 28, 2004.
  1. wickedmach1 New Member
    Apr 9, 2003
    Message Count:
    376
    Austin, TX
    I am painting and detailing the trunk for my 70 Mach. Who has used the splatter paint and how good does it look? This is a restomod so I am not worried about originality. Where did you spray the splatter paint? I want to use something other than just paint due to the metal being a bit pitted over the years. I think if I use this type of covering, it will hide the imperfections. I will use regular black carpet instead of the plastic original layins. Pictures would be appreciated. Thanks.
  2. 69 302/351c Founding Member
    May 29, 2001
    Message Count:
    1,146
    36
    Walkertown NC, originally Western Mass
    I used the splatter on my 351C 69 and it doesn't look too bad. Blends in the undercoated areas with the uncoated. Need to use the sealer after doing the splatter.
  3. xoxbxfx Founding Member
    May 10, 2001
    Message Count:
    3,963
    Southlake, TX
    What I plan on doing is using P0R15 to keep rust and stuff out, then adding the spray in bedliner.
Share This Page
