Differential Fill Plug
Discussion in '94-04 V6 Mustang' started by Adverse2Change, Jan 10, 2009.
  1. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    This mother #%(&#$ won't budge. I've tried blaster and other lubricants on it and it will not come loose. Any one have an idea on how I can get this thing loose? My differential needs more oil or it'll rip itself apart.
    Thanks
  2. MustangLX-5.0 Founding Member
    Dec 3, 2000
    Message Count:
    1,513
    You are using a 1/2" drive to access the plug ..right? Has it been removed before? And are you sure it NEEDS oil added to it? Might be best to just pull the cover off and change the oil out alltogether.Clean it up in there while your at it.Inspect the ring and pinion gears.
    When you PB the fill plug,make sure you let it soak for awhile.Try agin then spray again.
  3. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Yes I am using a 1/2" drive. No one has ever touched back there. My initial plan was to check the level, and then remove the housing and replace all of the fluid, but if I can't access the fill plug then there is no way to do that!
    I took it to a shop on saturday, test drove it with a mechanic, and he figures that my bearings may be going out... and since he's planning on basically dismantling most of the rear end I'm going to have him price some new gears for me.
    We'll see what happens.... gonna be some serious $$$$$. :(
  4. Skymarshal Member
    Nov 5, 2004
    Message Count:
    569
    Junkyard 8.8" rear end off a GT. Get everything you want all at once...
  5. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Is it absolutely necessary to go with an 8.8" rear if you want to go to 373s? I can understand going to a beefier setup if you are really going to be adding some major power, but what if you aren't?
  6. Skymarshal Member
    Nov 5, 2004
    Message Count:
    569
    No- you can put 3.73s in your 7.5" rear end. I was just thinking it might be easier since you have an unknown noise and you want to do gears anyway. Putting in the 8.8" would give you a limited slip too, which would be nice even if you don't have a power adder.
  7. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    I'm getting a good price on 3.73s with a locker in the stock housing...
    my bearings on the other hand....:fairyfight:
  8. MustangLX-5.0 Founding Member
    Dec 3, 2000
    Message Count:
    1,513
    Rear axle bearing kit with shims will run you $70 - $90.But that's for an 8.8 .Not sure about 7.5. It had cost me $90 for the 8.8 kit from Ford...and I work here (dealership).
    I wonder if you can just use an impact wrench on that plug? Hmm.Can't think of anything else if it wont budge.Sounds like you live up north and the gear oil has never been changed out of it.
Share This Page
