LXXVICOBRA said:
Yes, the II V-8's did use a shorter filter than the FL-1A...but, (at least for '76) service and owners manuals still recommended 4 quarts + 1 extra with filter change. However, I do have one chart that says (for '75 cars) 3 1/2 +1, which would coincide with what you said.
Yep,
Far as I know all II V8 pans are D5ZE, and during the '75 model year I'm sure Ford realized they would have a bunch of half quarts sitting around. For the younger readers: These are oil can days. No such thing as putting the lid back on the bottle.
I can also see the general public not liking having to toss a half quart if doing their own oil changes, or putting only 4.5 quarts when everything they changed oil in before took 5 quarts ..... and in '75 if they dumped 5 quarts in the pan it would show being overfilled. ...
Easier to change the stick and give the public what they expect, even if it means making the smaller sump oil level that much closer to the crank which is something I've never liked about the II pan. Fact, one of the things about the II pan that has always irritated me is how cast off / slung oil has to run so close tot he crank all the way back to the sump.
Overall I feel the switch to listing 5 quarts was more a move to give the public what they expect and less a move of solid engineering principals.
IMHO.
I remember switching to the longer FL-1A filter after the first couple of oil changes however,....It seems to me the number for the (short filters) was a PF-17, but I'm not really certain after all these years.
Same here. And it's been years since I've bought a Ford/ Motorcraft filter.
IIRC there were three lengths of filters sharing the Ford base.
Your method for draining and refilling prior to marking the stick makes perfect sense, assuming you had no measurements to work with and were unaware of the 3/4 " I mentioned between the add and full marks.
Assuming you have a factory II stick from any year, are aware of the above speculation and observations , blah blah ...
Only thing I can say with certanty is there really isn't an absolute answer.
And while Dykes would make a mark, I'd hesitate using them not only for the very valid reasons you stated, but because etching it lightly in another manner would probably be less likely to distort the stick, leave a burr, and give a better overall line.
All vallid points.
Truth is, anything done to the stick will weaken it, except possably etching with acid.
And around it goes.
I mark the edges because light nips are easy to remove, and don't cause stress risers across the plane of vibration.
But this is all jabber, it's more important to mark the stick at the proper level than the method it's marked.
