Dipstick Problem!!
hey im havin some troubles with my dipstick. Is it just me or is it extremley long? also my cars dipstick is bent towards the bottom and seems to not go in all the way. Anyone know the part number? maybe i have the wrong dipstick lol thanks <3:p
Pictures? Mine is not bent, but I have a 93 so who knows about yours for sure. I know that you can make almost any dipstick work as long as it is somewhat similar. You can make your own marks on it so you know the levels.
yea i might get pictures, um maybe there is suppossed to be a riseing tube or something connected to where it comes out of the oil pan, cause it is splashing oil eveywhere underthere so i need to probably replace it and see if im missing anything thanks though <3
no the dip stick should have a rib on it where it slips into the block and also should have a tab that is either mounted on the intake or fuel rail bolt...there are two things that cause it to leak.
1.movement from not being bolted down.
2. blow-by from a pressurized cranks case.
