do any v6 have limited slip dif?
Discussion in '2005 - 2012 Specific V6 Tech' started by herm25, Sep 26, 2009.
  1. herm25 New Member
    Aug 5, 2009
    Message Count:
    14
    russellville, AR
    ok i have a 2009 with pony package, i am confused because everywhere i read it says that they dont come with the limited slip diff.... i have done a burnout and i left two tread marks on road?? mine came with a rear sway bar already installed, is it possible it has trac-lok as well? i only ask because i am ready to order the 3.73 gears and need to know if i need to buy the traclok as well.
  2. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    Houston TX
    I'm sorry to say but the V6 did not come with an LSD unit. Your probably were at the sweet spot when you launched where both tires lost traction at the same time causing you to leave two marks. A better indicator would be to crank the wheel all the way in one direction and light them (or better) it up and you'll see only one wheel spinning as you start doing donuts.
  3. V6Vin New Member
    Sep 13, 2009
    Message Count:
    30
    Arkansas
    Check the door code sticker under "axle" will be two letters,
    BG — 3.31 — non-limited slip, base vehicle with manual or automatic transmission
    CD — 3.55 — limited slip, GT with manual transmission
    CG — 3.31 — limited slip, GT with automatic transmission
  4. The Fang Member
    Sep 11, 2005
    Message Count:
    619
    Tallahassee Fl
    I saw an ad a while back for Tlok kit around 200 bucks in 5.0 I think it was a UPR ad but cant find it now. :)
Share This Page
