Don't understand!
Discussion in '2005 - 2009 Specific Tech' started by powershift46L, Jul 6, 2007.
  1. powershift46L New Member
    Jul 1, 2005
    Message Count:
    Western TN
    I just bought 2007 GT with the 3:55 rear end option. I have had a 2000 and 2005 GT's in the past all with 5-speeds Transmissions. Both the 2000 & 2005 would indicate 68 mph at 2000rpm both having the stock 3:27 rear end. The 2007 with the 3:55 rear end seam to indicat the same about 68 mph at 2000rpm. I thought that I would see a difference maybe 65 or 66mph at 2000rpm. Has anyone else noticed this or would know why I am not running a higher rpm at 68mph?
  2. inferno9898 New Member
    May 18, 2003
    Message Count:
    249
    2000 and 2005 have different transmissions, and i would assume different final drive ratio, although I could be wrong. Seems weird to me that the 2000 and 2005 were the same. Could just be that the factory instruments aren't accurate enough to tell?
  3. ski Member
    Dec 14, 2004
    Message Count:
    367
    I don't know about the 2000 GT, but the 2005 GT with a manual tranny has standard 3.55 gears.
  4. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    My 07 GT speedo reads about 3 mph faster at 60+ mph, so 65 mph on the speedo is really about 62-63 mph using GPS.
  5. inferno9898 New Member
    May 18, 2003
    Message Count:
    249
    Is GPS more accurate than the speedo?
  6. ski Member
    Dec 14, 2004
    Message Count:
    367
    The original 2000 Mustang GT had 16" tires(17" on the mid-year and later models). So if it had a 3.27 gear like you say, then that would translate to an approx. 3.47 gear with 17" tires. And that would make the rpm's at 68 mph very close to the 2007 GT with 3.55 gears(assuming it has 17" tires).
  7. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    I was told GPS is much more accurate, and I have noticed that even though my speedometer shows I am doing the speed limit, everyone is still passing me or tailgating me.
  8. inferno9898 New Member
    May 18, 2003
    Message Count:
    249
    Haha well if you are doing the speed limit, I would be passing or tailgating you as well.
    It seems to me like GPS wouldn't be accurate enough for speeds in cars because of any slight delay or tranmission errors in communicating with the satelittes. Seems like the most accurate measure would be from the tires that touch the road, but that also requires the correct calibration. Don't know...just rambling.
  9. harrison New Member
    Apr 10, 2007
    Message Count:
    27
    My Garmin GPS claims an accuracy of +- .05 meters/second. That's pretty accurate. I use it all the time on the highway and hiking.
  10. inferno9898 New Member
    May 18, 2003
    Message Count:
    249
    Interesting. What sort of Garmin? My girlfriend has one of the cheaper models that is designed to sit on a car windshield. I don't know what accuracy it claims, but just in watching it, I figured it wasn't that useful. Seemed to update too infrequently and seemed sporadic.
  11. chubhunter New Member
    Apr 2, 2007
    Message Count:
    63
    heartland
    I agree. I have used my Garmin on many road trips and I am convinced it is very accurate. Just my 2 cents.
  12. metroplex Member
    Sep 7, 2003
    Message Count:
    401
    I used my Garmin ForeRunner 101 to check the speed and the speed reading was very steady. I even kept the vehicle speed steady to make sure, and sure enough the speedo was reading 2-3 mph faster consistently.
  13. harrison New Member
    Apr 10, 2007
    Message Count:
    27
    GPS Map 60CS. We wander into the hinterland so we needed a way to find our car again. Works great as a companion mounted on the window during long trips although the screen is pretty small. It also has a habit of picking roads that no longer exist for a route....
  14. mustangmike6996 Member
    Nov 11, 2005
    Message Count:
    570
    clinton twp, MI
    THE 2005 MUSTANG GT HAS A 5TH GEAR RATIO OF 0.68:1 WITH THE 3.55:1 WITH
    THE 3650. THE GT'S WITH THE 3.31 HAVE A 5 RATIO OF .71:1
    THE 2000 MUSTANG GT HAD A REAR GEAR RATIO OF 3.27:1 WITH .67:1 5TH RATIO
    SOME SIMPLE MATH AND THE 2000 MUSTANG GT HAS A LOWER DRIVING RPM AT THE SAME SPEED IN 5TH
  15. FordTaurusSHO94 Member
    Apr 15, 2003
    Message Count:
    347
    But the 2000 also had slightly shorter tires, right?
  16. powershift46L New Member
    Jul 1, 2005
    Message Count:
    Western TN
    Don't understand
    In 1st gear what speed do you guys run at 3000rpm? And what rear end ratio?
  17. ski Member
    Dec 14, 2004
    Message Count:
    367
    No need to shout.
    If the 2000 GT was a mid-year or later model, then it had 17" tires, and I agree with you.
    But if it was made in the 1st half of the model year and thus had 16" tires, then it would have the same rpm at the same speed.
  18. SlideWRX New Member
    Jan 8, 2007
    Message Count:
    127
    Westland, MI
    Er, the 2000 mustang had 16" wheels, while the mid year had 17", but the tire diameters were likely identical. :) What were the tire specs for those?
    And when my speedo reads 70, I'm doing ~68 mph. pretty common, you won't find cars that read exactly right from the factory. They all indicate a bit higher.
    Tom
  19. ski Member
    Dec 14, 2004
    Message Count:
    367
    Whoops, you're right. However, the end result is the same.
    The 2000 GT has either 225/55-16 or 245/45-17 tires with a 25.7" OD, and the 2007 GT has either 235/55-17 or 235/50-18 with a 27.1" OD.
    That would make the 2000 GT's 3.27 gear into an equivalent 3.45, or an almost unnoticeable difference of approx. 50 rpm's at 68 mph.
    In addition, 2 tires with the same specs from different manufacturers can have different rev/mile numbers, which in turn can make the engine rpm's for these 2 cars identical at the same speed.
Share This Page
