Door Hinge Pins
Discussion in '2.3L (N/A & Turbo)' started by tlpilot, Aug 21, 2004.
  1. tlpilot New Member
    Aug 18, 2004
    Message Count:
    34
    I am trying to get the door hinge pins out to replace the bushings on my 88. Is there an easy way to do this. I used a sawzall to cut the top of the pin (the part that looks riveted) and wacked the pin with a punch and 3Lb sledge, but I cant get it to budge. What gives?
  2. TurboFlush Founding Member
    Dec 8, 1999
    Message Count:
    1,984
    find the hole in the center of the pin, drill it out and the pin will break in two. then you just pull the pin out of each end.
    to simple.
    well not really.
    I helped a guy do his doors and it sucked.
    but that is basically how.
    The doors are heavy to!
  3. tlpilot New Member
    Aug 18, 2004
    Message Count:
    34
    Thanks... I think I got it on lock :lock:
    Greg
  4. Ray III New Member
    Feb 10, 2004
    Message Count:
    604
    there's no hole in the middle of factory pins...
    just gotta HE-MAN on that pin to budge it, maybe you should relieve the weight of the door too.
  5. tlpilot New Member
    Aug 18, 2004
    Message Count:
    34
    I put the air chisel to the pin. I made a notch in the pin and used the air chisel to drive it down. I also got the help of a guy here in the firehouse who was wealth of help. If he wasn't here, I'd be stuck.
  6. Asha'man Founding Member
    Feb 6, 2002
    Message Count:
    1,917
    I ground my pins in half with a dremel, took about an hour per. Don't forget to support the door, or you could end up with a crinkled lower corner like mine. :(
    Ash
  7. TurboFlush Founding Member
    Dec 8, 1999
    Message Count:
    1,984
    some have holes and others have a dimple. This is the way ford does it.
Share This Page
