door speaker
Discussion in '94-04 V6 Mustang' started by mstng02, Aug 23, 2005.
  1. mstng02 New Member
    Aug 22, 2005
    Message Count:
    got a 2002 v6 stang. speaker in the passenger door is blown, how do you get the door panel off to get to the speaker?
  2. AndyG47 New Member
    Aug 21, 2004
    Message Count:
    124
    Done this alot myself.
    1. Open the door obviously
    [IMG]
    2. Remove the pop 'em bolt on the bottom front corner
    [IMG]
    3. There is a small tab above the switch bezel press down on it (not much force required) with either your fingers (recommended) or a flathead screwdriver and pry outward then pull up on the whole thing and it will pop off.
    [IMG]
    4. Take the two screws off the swirch bezel on the underside
    [IMG]
    5. Then these two on the door.
    [IMG]
    6. Then get a grip on the door and pull up and out (watch for the door handle)
    Re-installation is reverse with a few things.....
    the door has a lot of hooks on the back make sure they all go to their proper holes and work with the door unlocked so you can put the lock pin in the little hole in the top of the door.
    NOTE: Photobucket still uploading, pics coming soon.
    NOTE2:The factory 5x7 speaker can be replaced with an aftermarket 6x8, it will fit.
  3. mstng02 New Member
    Aug 22, 2005
    Message Count:
    Thank you.
  4. FunkMasterFlex New Member
    Sep 18, 2003
    Message Count:
    85
    great post! very helpful with the pictures :cheers:
  5. doc4444 Founding Member
    Jul 11, 2002
    Message Count:
    235
    I agree with everyone else, THANK YOU. I myself have been wondering how to do this for quite awhile. The pics truly make it seem easy. We should have a little "how to" forum as well as the tech and talk forums to add these little gems to.
  6. zincyellow03 New Member
    Jul 6, 2004
    Message Count:
    888
    Nice write up Andy. I think you should add this to the sound forum, so it could help others.
  7. AndyG47 New Member
    Aug 21, 2004
    Message Count:
    124
    Thank you all and You're Welcome.
    Zinc. Copied to sound forums, I also did one for the rear cause while I was there I saw someone had started a thread asking about the rear.
  8. OxMox turkeysammichesonhisface
    Mar 31, 2005
    Message Count:
    611
    :banana: ANDY :banana: WooT wOOt!!!11
    Look at you go! Now cna you do a write up of how to remove the factory Cam and Crankshaft and then install a new cam and crankshaft? :rolleyes: 'cause that would be teh cool! :hail2: :hail2: :hail2: Seriously, good job
  9. AndyG47 New Member
    Aug 21, 2004
    Message Count:
    124
    Thank you.
    Sorry no. I'm not that much of a gear head (yet) I can really help with visual, sound. But only SUPER BASIC engine stuff.
  10. TheRican Emo Extraordinaire
    May 7, 2002
    Message Count:
    691
    I am not usually a fan of the painted inside pieces, but I like it.
    Oh, and hope the speaker install went groovy.
Share This Page
