Dream modular build...
Discussion in 'SN95 4.6 Talk' started by bhuff30, Oct 17, 2009.
  1. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    I'm sure i'm not the only one to dream about what kind of modular they would build for their mustang if they had substantially more money than they do... but I do think my ideas are a bit different from some of you others.
    So post it up. What would be your dream modular build? A high compression, naturally aspirated pump gas with trick flow heads and a nasty cam? Vortech build-up?
    After we get a few replies, I'll post up my ideas of fun with a modular.
  2. scupking Active Member
    Sep 19, 2005
    Message Count:
    1,198
    36
    I have my dream build for my car. I think 350hp out of a 4.6 N/A is darn good.
  3. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    So what's that setup?
  4. 5.0Torx Active Member
    Dec 30, 2007
    Message Count:
    256
    26
    Um....Ford GT motor with twin turbos!
  5. 2011_Ram_RT Mustang Master
    Mar 31, 2005
    Message Count:
    4,874
    21
    78
    A Novi 2000 with intercooler, built up 4R70W, a bullet proof bottom end, and a redone suspension.
  6. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Built bottom, w/ the new trickflow heads, and a big ole' blower maybe something in the tork tech flavor. The trans. would be either a T-56 or TKO-600, I am undecided if I want a 6-speed or not. Im not looking for outrageous numbers but something fun and reliable enough for DD duties if I wanted it to be daily driven. Obviously it would have a full exhaust and wicked suspension.
  7. stang06girl Member
    Nov 8, 2008
    Message Count:
    30
    5.3 stroker
    Option 1
    -Boss 5.0 3.75 bore mod motor block
    -Forged 8 bolt stroker crank, Oliver billet rods, Forged 9.25 CR pistons
    -large valve cnc ported 3v heads, Comp Blower cams
    -A KB 2.6 stage2 (130mm throttle body), Dual GT500 pumps, 60 lb injectors
    -A beefed up Lentech 4r70w with a trans brake, 2800 rpm PI stall converter.
    Option 2
    Same as option 1, except a KB 2.8 or Whipple 3.4.
    Option 3
    Same as option 1, except 4V heads, and a KB 2.8 or Whipple 3.4.
    Option 4
    Same as option 3 with slightly lower compression, turbo cams, and one hell of a kick ass turbo with 30 lbs of boost
    Option 5
    Same as option 3 with slightly lower compression, 4V heads, with a huge centrifigal blower.
    Option 6
    John Kaase 825 ci Boss hemi with a 12.71 blower .... oops not a mod motor!
    I went for Option 1
    (KB 2.6 on the car, shortblock in the garage) No heads or trans yet.
    I'll go for Option 2 or Option 3 after I recover from paying for Option 1. LOL!
    Horsepower .... It's an expensive and incurable disease!
  8. Winters98GT Founding Member
    Nov 29, 2000
    Message Count:
    5,458
    10
    78
    white aero cobra, 03-04 swap with a single or twin turbo, and a t56.
    Stock mufflers, custom headers with cats. Stock rear wheels widened to 10 inches with a set of drag radials.
    Complete sleeper car, until they hear the turbos rev up.
  9. sneaky98gt Well-Known Member
    Apr 24, 2008
    Message Count:
    2,490
    9
    58
    03 Sonic Blue Cobra. Hellion Hellraiser twin turbo system compounded on a ported and pullied Eaton. All the drivetrain to support 800ish hp. And as Winters said, fairly quiet exhaust. Definitely want a sleeper car. Hence "sneaky"...hehehe.
    As an example: YouTube - Hellion Hellraiser Twin Turbo 03 Cobra
    -Will
  10. Poisoned Pony Founding Member
    Dec 18, 2000
    Message Count:
    288
    2v dream build:
    - WAP block
    - 10.5:1/11:1 compression
    - Trick Flow heads, ported & polished
    - Modular Head Shop cams
    - Trick Flow or Bullitt intake, ported
    - sauced with a 150-175 shot
    - back it with a built T-45
    4v
    - WAP block
    - 11:1 compression
    - Terminator heads, ported and polished
    - '96-'98 cams
    - short runner Mach 1 intake
    - same amount of nitrous
    I like nitrous setups. To me, it's something different and have good potential if you plan out a build :nice:
  11. scupking Active Member
    Sep 19, 2005
    Message Count:
    1,198
    36
    Its all in my sig below.
  12. stang06girl Member
    Nov 8, 2008
    Message Count:
    30
    Compounded! Me like!
  13. nickmckinney Member
    Sep 25, 2009
    Message Count:
    164
    Since I like to be different:
    Ported NPI heads
    Modularheadshop NPI Stage 3.5 cams
    Mark VIII bottom end
    Edelbrock stepped long tubes (last set they made)
    And the icing on the cake:
    [IMG]
    Its possible it will be the only Logan/NPI motor in existence :D
  14. navarro98gt Member
    May 15, 2003
    Message Count:
    215
    This is my dream set-up but with a built 4R70W.
  15. sneaky98gt Well-Known Member
    Apr 24, 2008
    Message Count:
    2,490
    9
    58
    Yea, no joke. 10 lbs of boost off idle, then 35+ pounds in the upper rpms...:drool:.
    -Will
  16. EPIK New Member
    Jul 3, 2004
    Message Count:
    830
    Mine would be my current car with a big bore stroker 03/04 Cobra motor, but with a Teksid block, a big whipple, T56, & a built IRS....
  17. stang06girl Member
    Nov 8, 2008
    Message Count:
    30
    I just had an evil thought ....
    Maybe I should forget about the KB 2.8, Whipple 3.4, or huge centri, and just compound my KB 2.6 with a Hellion twin turbo system. That's gotta be better than compounding an Eaton. That would be an insane combo!
  18. Dragstr05 New Member
    Dec 22, 2004
    Message Count:
    652
    Built 5.4 with high compression, 4v heads, stage 2 - 2.5 N/A cams, and an aussie boss 290 intake. Nitrous for the just-in-case. T-56, built rear with maybe 3.55's, MM suspension. Custom longtubes, and bassani the rest of the way.
    -or-
    5.0 BB, T/F heads, single turbo, turbo cams, T-56, 3.55 gears, MM 3 link in the rear.
    Both set ups with the aim of being completely streetable. Yes, you can drive a 800 - 1,000hp car on the street but IMO that wouldnt be any fun. It has to have predictable power that doesnt kill itself in the corners. 100% DD capable, rain or shine (minus snow).
  19. Gearbanger 101 SuperMod
    Aug 11, 2002
    Message Count:
    10,662
    88
    Twin Screw + Compound Boost = no go
    Twin Screw compress the air between the screws within the confines of the case housing itself....unlike an Eaton which compresses the air within the lower manifold. Meaning trying to force feed a screw compressor is going to lead to insane ACT's and eventually a broken blower.
    What's the matter....a 1,200hp capable Twin Turbo/Eaton M112 combination isn't enough jam for you?
  20. N8Dogg98 Mustang Master
    Apr 5, 2005
    Message Count:
    8,405
    94
    88
    Mark VIII/96-98 Cobra short block
    ported Trick Flow heads
    extrude honed trick flow intake manifold
    custom grind cam
    LT headers
    7,000 RPM screamer... yeah baby
Share This Page
