Driveshaft
Discussion in 'Mustang II' started by 54deuce, Jun 9, 2009.
  1. 54deuce Member
    Jun 1, 2009
    Message Count:
    104
    For a T-5 swap did you guys use the stock II driveshaft or did you have to add 2inches to it? Infact my car was an auto before is that drive shaft the same as the 4spd or are they differant? I went to get my driveshaft balanced yesterday and the guy said it looks alittle short he seen the rub marks from the seal and it should be in more. He said that would cause vibration at higher speeds. It does vibrate at 60 and up not to crazy but noticable. I dont even know if I have the right driveshaft in the car.
  2. 54deuce Member
    Jun 1, 2009
    Message Count:
    104
    I would like to try the ford racing one.
  3. dmoody Founding Member
    Nov 4, 2002
    Message Count:
    798
    Winston-Salem, NC
    For a T-5 swap, you have to cut 2 inches off the stock (manual) driveshaft. I don't know about the driveshaft in an automatic. The driveshaft yoke should stick out some from the transmission otherwise when the rearend articulates it will bind up.
    david
  4. Dano78 Founding Member
    Nov 1, 1999
    Message Count:
    2,662
    Vancouver, WA
    Could have sworn that the C4 driveshaft was 1.5" shorter than the RAD 4 speed driveshaft. See if I can find one in the pile to measure.
  5. 54deuce Member
    Jun 1, 2009
    Message Count:
    104
    I measured it and got 46 inches. I went back to the guy and we measured the driveshaft and it was 46 inches so I dont know what the hell happened.
  6. Steel Steeds New Member
    Sep 1, 2005
    Message Count:
    239
    Portland, OR
    That depends on which bellhousing you use. 2" sounds right with the II bell, I only had to take 1" off of my driveshaft using the Fox body bellhousing.
  7. 54deuce Member
    Jun 1, 2009
    Message Count:
    104
    I am using the fox bellhousing also. The guy told me the yoke shoulder has to be 1inch away from the trans and thats what it is.
Share This Page
