Dull Headlights
Discussion in 'Mustang Sound & Shine All' started by 85MustGT, Jun 22, 2004.
  1. 85MustGT Founding Member
    Nov 8, 2001
    Message Count:
    344
    Occupied San Diego
    As most GTs my headlights look like crap and I do not have enough money to buy fancy ones. Can a sand them with 400 grit paper and use polishing compound?
    Whats the best way to brighten them up a bit?
    Do you have to take them out? :shrug:
  2. Saleen4971 New Member
    Mar 27, 2003
    Message Count:
    691
    Setauket, LI
    its probly easier to take them out. but first, try some rubbing compound on them, that might help. if not, wetsand, then compound, then a finer abrasive, should look good.
  3. rjstaaf Founding Member
    May 31, 2002
    Message Count:
    1,309
    Upstate, SC
    I would not start with 400 grit. I would start with something like 800 grit and work you way up to 2000 grit. That will make it easier to remove the sanding marks with a compound. I don't think there is a rubbing compound out there that will remove 400 grit sanding marks but, then again we are talking plasic. Why make it hard on yourself though.
  4. EpiKk3 New Member
    Jun 4, 2004
    Message Count:
    408
    tell us how it works out.. ill eventually be getting some smoke headlights.. but i dont have the proper funding right now :rolleyes:
Share This Page
