Earlier Model Mustangs have stronger blocks?
Discussion in 'SN95 4.6 Talk' started by snowboarder1988, Oct 8, 2006.
  1. snowboarder1988 New Member
    Jul 11, 2006
    Message Count:
    29
    I was talking to a guy the other day who said that the 99, 00, and 01 mustangs have stronger and better quality blocks than the later years, 02, 03, 04. Is there any proof of this or is this guy crazy?
  2. dsg03bullitt New Member
    Jul 25, 2006
    Message Count:
    Im just shooting in the dark with this theory but i think hez carazzzyy
  3. 04YELLOWGT New Member
    Jun 30, 2005
    Message Count:
    1,197
    Butl some were built in different plants.
    There are like Windsor and Romeo blocks right. I dont think ones stronger than the other though
  4. jstreet0204 New Member
    Jun 27, 2003
    Message Count:
    1,813
    99-00 models had the windsor block.
    The main bearing caps on the Windsor are larger than those on the Romeo. The Windsor also uses dowels between the caps and the block, whereas the Romeo uses jack screws between the caps and the block. The Windsor has larger connecting rods with full-floating piston pins and two retainers. The Romeo has press-fit piston pins with no retainers.
    The Windsor's camshaft sprockets are pressed onto the camshaft. The Romeo's cam sprockets are held on with a bolt and spacer. The Windsor uses eight bolts to secure the flexplate to the crankshaft. The Romeo uses just six bolts for the flexplate. The windsors are built a little stouter, but neither are weak enough to make it matter.
  5. triggz Founding Member
    May 15, 2002
    Message Count:
    1,291
    99-00's use the windsor truck block as stated above, due to a fire at the romeo engine plant. the windsor motor is the f150 4.6
  6. deftsound Please ask me how much my supercharger cost
    Apr 6, 2004
    Message Count:
    1,681
    good to know
  7. dsg03bullitt New Member
    Jul 25, 2006
    Message Count:
    Well i'll be damned, I learn more everyday!
  8. GitDat Founding Member
    Mar 24, 2002
    Message Count:
    521
    I've heard that the 99-00's have lower compression too :nice:
  9. Trav4011 New Member
    Jan 4, 2006
    Message Count:
    193
    I've heard that the Windsor built engine's pistons have a thicker top ring land.. is this true?
Share This Page
