Ecu Question
manny
590
TAMPA FL
i have a n/a 1987 mustang w/2.3L 4cyl that i run in the SCCA. My problem is that it runs really lean on the high rpm like 4500 to 6500. My question is can i install the ecu from a 87-88 TC along with the vam and the 35lb injectors in order to help the very lean condition i have in the high rpm range? BTW the car has a SD EFI setup. Also the head has been ported, milled and i have a larger throtle body and 19lb injectors.
If you swap ecu's to the LA3 you will need a QH to tune the ecu. I've been there and done that on an n/a engine...
It will work, but it never worked right for me.
Depending on what ecu you have, at least one of the 2.3 n/a ecu's can be tuned with the QH.
Or, I am currently running a '95 Mustang v8 ecu on my n/a 2.3.
Running pretty good for what it is...
Oh, I had to repin it... lol
It wasn't too bad though...
Check here..
http://eectuning.org/forums/viewtopic.php?f=2&t=17706
No reason you couldn't use an A9L or just about anything else for that matter...
Interesting.... I'll have to read that thread when I get on my home computer, on my work computer that site is blocked. That is a very interesting way to do it. I'm going to toy with the stock 93 2.3 computer first to see if I can make it work.
