EEC-V or EEC-VI?
Discussion in '2005 - 2009 Specific Tech' started by 88 Fox GT, Nov 26, 2004.
  1. 88 Fox GT New Member
    Nov 19, 2002
    Message Count:
    1,853
    Iowa
    Is the 2005 using an EEC-V or EEC-VI? I read that the EEC-VI came out in 2003, but Fords website still claims that most of their 2005 vehicles are using EEC-Vs. :shrug:
  2. 351CJ New Member
    Dec 12, 2002
    Message Count:
    1,769
    It's probably EEC-VI. The Mustang uses the "Black Oak" PCM system which is the same thing that the 2003 and new Lincoln LS & T-Bird use as well as the 2004 and newer F-150.
  3. FordRacing New Member
    Oct 26, 2004
    Message Count:
    49
    Buffalo, NY
    According to the ford web site it’s a EEC-V.
    http://www.fordvehicles.com/cars/mustang/features/
    2/3 of the way down the page, under power.
  4. tripleblackragtop New Member
    Dec 18, 1998
    Message Count:
    12
    Royal Oak, MI
  5. 351CJ New Member
    Dec 12, 2002
    Message Count:
    1,769
    Thinking about it some more, are you sure that you didn't read that EEC-V came out in 2003 and most products were using EEC-IV until that point? A lot of Ford products switched to the new PCM system in 2005 which I assume is EEC-V
  6. 88 Fox GT New Member
    Nov 19, 2002
    Message Count:
    1,853
    Iowa
    351CJ, as soon as OBD-II came out (1994), the EEC-V came out and the EEC-IV was no longer used as it could only support OBD-I. There were actually 2 versions of EEC-V. First was in '94 (other than Mustang as it was still using EEC-IV) and the second came out in '99.
    Here is where I found the info about EEC-VI.
    http://fordfuelinjection.com/index.php?p=2
  7. Darkhorse845 Banned
    Nov 17, 2004
    Message Count:
    236
    Las Vegas,Nevada
  8. 351CJ New Member
    Dec 12, 2002
    Message Count:
    1,769
    Nice link Speed Demon1965.
    It sounds like the correct answer is EEC-V 2.0, the newer flash memory version. Just saying it is EEC-V leads to confusion that the PCM system is the same as what is in the 99-04 Stangs, which is not the case.
    However Ford did not introduce ETC until the 2003 Model year, so something had to change to handle the ETC, which the 2005 Stang has.
Share This Page
