EGR System
Discussion in '2.3L (N/A & Turbo)' started by QangMartoq, Feb 28, 2004.
  1. QangMartoq New Member
    Feb 28, 2004
    Message Count:
    46
    Lakeland, FL
    Back again with another q, '87 LX Vert w/ 2.3 4-cyl & A4LD auto trans, my EGR system seems to be shot.
    I don't see a Check Engine light anywhere in the car, where is it? Mine must be burned out, I checked it at AutoZone, pulled two codes, 83 and 84..
    Anyways.. I'm getting really crappy mileage, and although the car wants to stall out when it's cold, and it's hard to start, it does run well when it warms up. It just gets really crappy mileage. I did 210.8 miles on one tank, that being a 15.4g tank. (13.68 mpg)
    The codes seem to be putting the blame on the main EGR control solenoid, I looked at it and its connections, nothing visually amiss, is there any way to test the solenoid?
    If not - Anything else I should check/replace, such as the EGR valve itself?
    Thanks...
  2. Tru_Blue_104 New Member
    Nov 14, 2003
    Message Count:
    218
    MN
    well, i didnt even bother replacing the egr, too expensive. I just pulled the vaccume hose off of it and pluged it, works just fine. never had any problems.
  3. Beefy New Member
    Jun 22, 2003
    Message Count:
    63
    Toronto, Ontario
    The EGR on our cars all nothing but a pain. The hole they have to actually let the gas into the intake is so small it barely effects anything. Even fully functioning, it only robs performance.
    I just passed Ontario emmisions yesterday with no EGR and I had the best scores the shop had seen in 2 months on any car, new or used.
    I suggest pulling the vacum line and plugging it, pulling the harness and then if you have access to a good code box, delete the code thats popping up.
  4. 93GreenLX Founding Member
    Aug 22, 2002
    Message Count:
    780
    Southern Maryland
    I also just plugged the vacuum hose, haven't had any ill effects in 2 years
Share This Page
