Engine Failsafe Mode
Discussion in '2005 - 2009 Specific Tech' started by 199, Feb 4, 2006.
  1. 199 New Member
    Apr 22, 2005
    Message Count:
    109
    Let me start of by saying my car is completely stock*, I have not modded my engine or anything else on the car, I also have not installed or flashed a tune, again for clarifications my car is STOCK,
    Okay I did a search on the “Engine Failsafe Mode” on MSN, Google, and Yahoo not much came up, I did a search on allfordmustangs.com and stangnet.com nothing of much relevance came up, Others mustang owners that got this message have a tune on there car again I don’t.
    So my brother was driving the car and he got this message, the car switched to lower power and I guess didn’t shift properly (automatic) this is of course for engine safety reasons, he took it to the dealership directly they are looking at it hope they can figure out the problem.
    By the way the user manual has no explanation of what might have caused a problem,
    Anyways my question is what caused this has anyone else experienced it?
    Is the Engine Failsafe Mode equivalent to Check Engine light or does the car have both?
    *(few cosmetic mods this is irrelevant but that just to make everything clear)
  2. 199 New Member
    Apr 22, 2005
    Message Count:
    109
    I found a couple of posts from a f150 forum and a few others some are not a mustangs, guess its similar system
    http://www.f150online.com/forums/showthread.php?t=138647
    http://www.tunercarz.com/driverforum/showthread.php?t=2943
    here are soeme Mustang related qoutes, the above quotes are for ford cars but not mustangs
    http://forums.bradbarnett.net/index.php?showtopic=21615
    http://fenway.net/board/viewtopic.php?p=16277&sid=fa8fc31fd9bea0cfdf52e948a5f7fe0e
    Useless post about this,
    http://www.mustangworld.com/forums/showthread.php?t=374740
    Fail-Safe Cooling
    A fail-safe cooling system lets Mustang be driven under limited power for short distances if engine coolant is lost, eliminating the cost and inconvenience of towing. If the coolant level sensor reads below a critical level, the engine computer module switches the engine to an emergency limp-home mode, in which only half the cylinders get fuel. With only half the cylinders firing, the engine operates at lower power and generates much less heat. The cylinders alternate between even- and odd-firing pistons in this mode. The engine can move the vehicle at moderate speeds (up to about 50 mph).
    http://www.carseverything.com/action/printarticle/1521/
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    i was going to suggest many of those ideas. its hard to tell directly what caused the problem without a proper diagnostic troubleshooting. thats why it went to the dealership. i thought dealerships overseas had problems working on domestic cars. :shrug: just seems like i heard someone say that the ford dealerships where they were at didn thave any equipment/experience to work on their 05. i hope you get it fixed quickly and without any hassles.
  4. 199 New Member
    Apr 22, 2005
    Message Count:
    109
    As expected the dealership couldn’t find a problem with the car, I hope it doesn’t occur again,, I hate it when I have to take my car to the dealership.
    They said they hooked it up to the diagnostic computer, but no faults or errors showed up,
  5. txblue New Member
    Aug 20, 2009
    Message Count:
    Did you check the TPS
    My 2005 mustang did the failsafe engine check thing and from everything I found it was the Throttle Position Sensor - so we replaced that for $100....fixed the problem for months - until yesterday. Didn't have time to deal with it today so drove a different car, but I want my Mustang back - not sure if we should try that again or take it to a shop - it was an easy part to change - 2 screws and done!
  6. tr7driver Member
    Sep 5, 2006
    Message Count:
    89
    ditto
    Mine did the same thing, throttle sensor. Fortunately I had about 200 miles left on the warranty when it happened. It was a quick fix and no problems later.
  7. imfamousjim New Member
    Mar 13, 2009
    Message Count:
    31
    mine did it once, i used my tuner to pull the code, and it was throttle position stuck open. I hear replacement of throttle body is usually necessary, but that was 3 months ago and i've been fine since then.
  8. 05roush New Member
    Mar 22, 2008
    Message Count:
    this is definately good to know considering my car is an 05 also....havent had this problem yet but at least I have an Idea what to look for if it happens thanks fellas.
  9. ElCid2006 New Member
    Dec 9, 2003
    Message Count:
    83
    I had the same issue with the Throttle Position Sensor. The yellow wrench fault light was intermittent at first and then came back on with a check engine light. The dealership fixed it for $100 and I haven't had any problems since.
Share This Page
