Engine is shot
Discussion in 'SVT Forum' started by 99cobraNix, Aug 21, 2004.
  1. 99cobraNix New Member
    Jul 24, 2004
    Message Count:
    My 99 cobra is dead. My oil pan was damaged, and it deprived the engine of oil. So now I am left with the decision of what to do. I was thinking, of getting a new stroker motor, or maybe an 03 motor. I was told that an 03 motor could bolt up to my car, as long as I had the 03's ecu. Has anyone done this? I would like to know some info on this swap, or if I should even do this. Maybe I should just try to rebuild my current engine. Another factor is money, I am doing this through insurance and the engine will be appraised this Tues, so I am not exactly sure about the amount I will recieve from the Insurance company. Any info would be greatly appreciated.
  2. 12 sec. 99 New Member
    Aug 10, 2003
    Message Count:
    63
    I really dont think the insurance money will be enough to cover an 03 motor but if you could somehow swing it and it'll fit i couldnt pass it up. good luck
  3. ironmedic New Member
    Mar 18, 2003
    Message Count:
    1,366
    or u can just get a 2v motor and put it in :) hehe
  4. Beau Founding Member
    Jan 29, 2000
    Message Count:
    3,406
    why not just buy a mach1 motor? its way cheaper than an 03/04 cobra motor.
  5. stallion98gt New Member
    May 12, 2003
    Message Count:
    1,815
    rebuild yours with good forged internals...better and cheaper than buying a 03 cobra engine
  6. missouri_guy197 New Member
    Sep 1, 2002
    Message Count:
    1,441
    :stupid:
    Rebuild yours and it'll be lighter and less costly than an 03/04 Cobra/Mach engine and just as strong...
  7. 5.0's 4 ever The #1 Stunna
    Jan 22, 2000
    Message Count:
    5,833
    76
    Rebuild it with some forged internals
  8. GoBabyVroommm New Member
    Mar 22, 2003
    Message Count:
    1,158
    I really don't understand why you would need a 03/04 computer. I was told i need a 4v cpu for my motor to work. Well my 4v is running on a 96 gt computer and it is fast as all hell. <No problems!>
    Don't waste your time trying to get that 03/04 motor, to much money. Have your motor built but becareful because to many people aren't good at building 4vs.
    Go to DSSracing.com they build good motors over there. You can get a built 4v short block for $3200, it can hold 700hp. I think its a good deal.
    You can always try just getting a 03/04 short from someone Karkraft.com may have one. I think they are selling for 2300-2700. Just remember your motor has a 9.8.1 compression and the 03+ have the 8.5.1 compression. You may lose some N/A hp.
    Even though my new motor has almost 3000miles on it i'm always looking for a deal on a built short block. Those places i have listed are just some of the places i check out.
  9. stallion98gt New Member
    May 12, 2003
    Message Count:
    1,815
    a built engine will always be better than a stock ford cobra engine since ur not cutting costs like Ford does :)
    I would go with some manley stuff, Oliver, CP,diamond...u pick...if money is fine..go billet and be ready to crank up the boost :)
  10. PJM99 New Member
    Aug 21, 2004
    Message Count:
    40
  11. GoBabyVroommm New Member
    Mar 22, 2003
    Message Count:
    1,158
    If you want either of them just look up Karkraft.com it would be cheaper. If you buy a mach just make sure you get one out of a stick than at auto.<meaning mach> The crank is stronger in the stick.
    Stock for stock the mach is a faster motor than your present one. Only problem you'll have with the mach is that it can't hold that much power. I think at 400 whp the motor blows. I'm sure people have ran there machs with that much hp but they blow up sooner than later. I don't own a mach i'm just telling you what i have read. Better off asking someone that has modded a mach1 and blew.
  12. 99cobraNix New Member
    Jul 24, 2004
    Message Count:
    Great advice so far guys. Another ?, what are the benefits of a long block vs a short block
  13. Tat98Cobra Founding Member
    Nov 2, 2002
    Message Count:
    799
    Longblock will be full assembled - usually costs more but it is put together from the engine builder so its more of a turn-key setup. Do lots of research on a good 4V builder in your area. If there is none - then yank that sucker out and go with a VTengine longblock -Ive heard nothing but greatness from them.
    peace
  14. stallion98gt New Member
    May 12, 2003
    Message Count:
    1,815
    I second vtengines
  15. JBVobra Founding Member
    Jun 12, 2000
    Message Count:
    599
    I think thats a load of crap that an aftermarket shop forged rebuild is somehow more reliable than a factory 04 cobra motor. That factory 8.5 comp is going to have tighter tolerances.
    Ask the reputable shop techs (off the record) if you don't believe me.
  16. GoBabyVroommm New Member
    Mar 22, 2003
    Message Count:
    1,158
    JBV it really depends who builds the motor. Just cause you can build a motor doesn't mean you know how to build them right.
    03/04 cobra motors are beasts but they do blow. I know a few people on the board that bought a new cobra and the motor was just about done. On the other hand i know people that have boosted that crap out of them and are still running hard. My point is its a hit or miss on that motor and factory isn't always the best way to go.
    Ford cuts a lot of costs anyway.
    As for the short or long block. Just get a short block. If you get a long block all your paying for is your heads but ports to whatever stage and some cams. Keep in mind the cams a lone are 1200 dollars and usually give about 30-40 hp.<Its not bad, i guess>
    Get a short block put some blower cams<if you have the money> and buy a Novi 2000 or ATI D1.
  17. GoBabyVroommm New Member
    Mar 22, 2003
    Message Count:
    1,158
    O yea for VT i hear nothing but go things about them.
  18. 5.0's 4 ever The #1 Stunna
    Jan 22, 2000
    Message Count:
    5,833
    76
    I heard the pistons are the weak link on the 03-04 cobra motors. I would personally put my Al Papitto built shortblock against one any day. When I had my engine rebuilt I didn't skimp on any parts like ford would do for a production motor. CP pistons, Manley rods, billet oil pump gears, arp main and head studs. I agree that the production 03-04 cobra motor is pretty stout but it could be a lot better for the $6k price tag of that longblock.
  19. Jpjr New Member
    Aug 5, 2004
    Message Count:
    148
    Motors are a lot like PC's.. if you know what your doing you can build your own component system that is just as good as an IBM for half the price.
    The Ford motors are safe choices but will cost a ****load.
    If the Mustangs are anything like Trans Am's.. (which I'm sure they are).. you should be able to find LOADS of info on the net about people with your car that have dropped in strokers/big blocks/blowers, etc. If you contact these people they will even send you templates for new motor mounts if you need to mod. Point is that your car is dead so the best thing to do is either get a new car or have some fun with it...
  20. Bob Cosby Founding Member
    Nov 8, 1999
    Message Count:
    287
    The stock 03/04 Cobra shortblock is very stout and very reliable, however, it's not bulletproof, and probably isn't the best choice for someone that is going to replace their motor anyways.
    There are a few reasons, among them the block. 03/04s use iron blocks that are almost 100 lbs heavier than aluminum. Unless your going stupid, stupid power, its just extra dead weight. Also, the pin area of the pistons are relatively weak, and when the stock block goes south due to excessive boost, it is usually this area that breaks.
    What I would recommend depends primarily on your budget and your goals. There are many paths you could go down, but an 03/04 motor swap is not the one I'd personally do.
Share This Page
