Engine light
Discussion in '2.3L (N/A & Turbo)' started by 351dreams, Feb 29, 2008.
  1. 351dreams New Member
    Jan 6, 2008
    Message Count:
    Orlando
    93 2.3L Engine light came on and the car idled down by about 1/2 normal. Sometimes it does it sometimes it doesn't. When its on I can be going 70mph and the RPM's are at 1500.
  2. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    Antelope Valley, SoCal
    A check engine light(CEL) is most easily diagnosed by checking for trouble codes...
  3. myitalian New Member
    Feb 29, 2008
    Message Count:
    seems like your injection problem maybe . . . doesnt have enough fuel or mix correctly to burn on
  4. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    Lord of uh, hmm what was it again?
    By the idle dropping, I assume you mean that the tach is off.
    If so most likley the DIS module is going bad ( On the front of the intake)
    Pull the codes, and you will probably have a code for a coil failure.
  5. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    yup, what SVO1 said. Codes will be 223 and/or 224
  6. 351dreams New Member
    Jan 6, 2008
    Message Count:
    Orlando
    223 was one of the codes. I guess I need to replace module. Thanks Guys. Also 23 came up which is the tps. The repair manuel says something about not replacing this on your own because it has to recailbrated when a new one is installed. Anyone heard of this?
  7. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,562
    66
    What kind of manual have you been looking at? Must be a Haynes or Chilton. :rolleyes:
    The TPS is usually adjustable(although some are not and have to be modified so they are). All you have to do is set the new one to the right voltage spec at closed throttle.
  8. 351dreams New Member
    Jan 6, 2008
    Message Count:
    Orlando
    Replaced the control module and the light went off. The car seems to be back to normal. btw its a haynes manual. Thanks Everyone.
  9. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    You misread the codes when you got the 23. That model year only used 3 digit codes. Earlier models used 2 digit codes, but never was there an EEC-IV ecm that used both.
Share This Page
