Ethanol????
Discussion in 'V6 Talk' started by 98CobraClone, Sep 2, 2005.
  1. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    Ripley, Ohio
    I know the whole idea of making ethanol is illegal for purposes of consumption, but how about using it as fuel? I have corn fields all around me. The basic principle is corn + sugar boiled = fuel, but will it tear up the fuel system?
    I have the basic knowledge of how to build it, and I've got welding skills, can weld up a still and boil my own stuff, so why not try it? Especially with gas prices at 3.65/gallon, this crap sucks
  2. OxMox turkeysammichesonhisface
    Mar 31, 2005
    Message Count:
    611
    Palm Harbor, FL
    You could try it, bu tmake sure to test it some how to make sure it'll work with your engine and not blow it all to hell
  3. GTA_V6_Mustang Active Member
    Nov 29, 2004
    Message Count:
    1,299
    36
    Miami, FL
    The octane rating in ethanol is way to high if i am correct so i dont think it would end to well but if it does let me know because i have corn fields around me too.
  4. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    Ripley, Ohio
    hmmm, so the octane rating is higher? that means the anti-detonation qualities are higher, and I could essentially run more boost safely...........I'm still researching the whole idea. I'd definitely run it through my carbureted car, dunno yet about the fuel injection thing though
  5. GTA_V6_Mustang Active Member
    Nov 29, 2004
    Message Count:
    1,299
    36
    Miami, FL
    yeah the octane is higher, alcohol is mostly ethanol hence alcohol dragsters.
  6. 77sleeper GO BUCS!
    Oct 11, 1999
    Message Count:
    7,495
    Napalm, AZ
    you will need different floats in your carb, eth will eat right through the ones you have
  7. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    Ripley, Ohio
    no biggie, I can go to the junkyard and get a carb for 5-10 bux. I'm more worried about probably having to get a plastic fuel cell, and all new lines all around
  8. GREENBIOCH Founding Member
    Mar 23, 2002
    Message Count:
    1,247
    In an Igloo
    I'm sure you would have to report the usage to the government or something like that.....I know the alcohols I use at my job are reported to some governing body as to how much we use so when the limit jumps up 20 times because some employee is using it for his meth lab operation they(gov't) know whats going on.....but yeah sure make your own.
Share This Page
