exhaust
Discussion in '2005 - 2012 Specific V6 Tech' started by spinmaster26, May 30, 2009.
  1. spinmaster26 New Member
    May 30, 2009
    Message Count:
    Im planning on converting my 2008 v6 from a single to a dual exhaust. I know that I want the SLP Loudmouths for an axleback but what else do I need? I want to customize my exhuast instead of buying a packaged catback system.
  2. Justin01 Founding Member
    Apr 22, 2002
    Message Count:
    549
    2 suggestions:
    1. If you want duals out the back similarly setup to a GT, then you'll need a GT rear bumper. You can sometimes find these at takeoff stores. Or if you want to dump them, which would make it rediculously and obnoxiously loud without mufflers, you could do that too.
    2. If you just want the SLP loudmouths, save yourself some money, go to a mufflershop, and just have them weld in straight pipes where the mufflers would normally go, pick out some nice 3.5 inch tips and your done. Less money spent and the same effect.
  3. TheVat New Member
    Feb 12, 2009
    Message Count:
    103
    Cross shop the boomtubes as well. Less expensive and not as raspy.
  4. spinmaster26 New Member
    May 30, 2009
    Message Count:
    Well all i heard that i needed was an axleback, midpipes and either an x or h pipe. What will the straight pipes do? I have an axleback picked out so all i thought i was lacking was midpipes and x or h pipe. Im not adept at exhaust research but that was what i found. Also i like the slps cause my uncle has it on his GTO and he is crazy bout them and reccomended them to me.
  5. slayr281 The poster formerly known as slayr420
    Jun 15, 1999
    Message Count:
    7,633
    I'm certain that the V6's still Y-pipe, so from your exhaust manifolds on each side, they will come together at a Y pipe, and then single pipe to a single muffler on the driver side.
    If that is the case, you'll need a midpipe (H or X pipe), and a muffler shop to weld those stock exhaust manifolds to the h/x pipe, and maybe put in a little custom tubing if it's not a direct fit. you'll also likely be looking at a catback for a GT, which has all the dual exhaust piping from the midpipe back, since you currently only have one pipe. You also need a GT bumper, or cut out from your v6 bumper for the exhaust tips, GT bumper is highly preferred if you care about the looks.
Share This Page
