factory replacement springs
Discussion in '2.3L (N/A & Turbo)' started by snoman12, Jul 3, 2005.
  1. snoman12 New Member
    Feb 27, 2003
    Message Count:
    15
    I am looking at getting a set of springs that are a little better than stock. I have 17 inch cobra r's and they fit pretty nice already in the fender, but my stock springs are getting worn out. I was looking at FRPP B or C springs. Will they fit on the car without any modification and still look right? It says that they drop the car 7/8" in the front and 1/2" in the rear, but is that only for the V-8s? I am sure the weight of a 4-cyl is not going to give it the same reaction, am i correct? I know that the Eibach pro kit is made specifically for the 2.3L but i do not want to drop that low, my driveway is to rough to have it that low.
    Also I am looking at getting a set of KYB GR-2 shocks and struts. Has anyone had them on their car and liked them? Are they a good shock?
    Thanks for everyones input. :cheers:
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    You could try the Motorsport springs, but I don't know how exactly they would sit on a 2.3L car. Might have to trim the fronts a little, not sure. If you look in the product reviews there's people that said the motorsport springs dropped their cars 3" or something, which I find hard to believe...so I dunno.
  3. SVOconvLX85 Member
    Mar 17, 2004
    Message Count:
    251
    Why does the eibach pro kit say it doesn't fit convertables? I didn't think there was a difference in hatchback and conv. springs.
  4. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    I thought it was because the convertibles were so much heavier.
  5. SVOconvLX85 Member
    Mar 17, 2004
    Message Count:
    251
    My convertable weighed less than the SVO
  6. Willy0314 New Member
    Jun 3, 2004
    Message Count:
    178
    if you run the prokit springs, you could get a set of urathane spring issolators. They would give you a bit of a "lift" so that the car wouldn't sit quite as low as the advertised drop.
  7. MrKwik Founding Member
    Jan 29, 2000
    Message Count:
    1,016
    I have the "C" springs on my 2.3 notch. I dont think it dropped at all in the front and very little in the back. It doesnt look lowered to me. It handles alot better than stock but I also have GT sway bars and steering rack. Rode stiff as all hell for the first couple months but its not so bad now. Either that or I got used to it, but I think the springs mellowed out some over time.
  8. tealtiger93 Member
    May 5, 2004
    Message Count:
    694
    MrKwik, any before/after pics?
Share This Page
