Ford Tech/Wiring Help needed
Discussion in '2005 - 2009 Specific Tech' started by MATRIX4.6, Jul 27, 2009.
  1. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    I bought a really ridiculous mod for my car, Train Horns....yes those. And I have all of the wiring down except the load wire from the stock horn. I am installing a switch to flip between horn and HORNS and need the guidance of a tech or someone with wiring experience particularly in the horn/steering column area. Thanks in advance for this odd request. I will post audio once completed.
  2. One2One New Member
    Jul 14, 2009
    Message Count:
    18
    -_________________________________-! i dont know what else to say....
  3. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    So what your are saying is you have no idea what I am talking about and felt like sharing just how vacant your intelligence really is?
    'Tis better to be silent and be thought a fool, than to speak and remove all doubt.
    - A. Lincoln
    "he who keepeth his mouth, keepeth his life. He who opens his lips to widely brings forth his own destruction."
    - Ben Wade
    "Your Car Sucks"
    - Me
  4. One2One New Member
    Jul 14, 2009
    Message Count:
    18
    Hehehheheheh
  5. Lotion New Member
    Oct 30, 2008
    Message Count:
    23
    :lol:
    Damn lol sorry man but i have to ask. Why would you want train horns on your mustang?
    I guess you would be unique thats for sure lol. WIsh i could help i do hope you find the help you are looking for.
  6. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,162
    38
    Nothing I can add.
  7. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    I bought a set for my truck and it wasnt loud enough so I bought another set for my truck and thought I would put them on the car... Seriously it can't be worse then putting a hitch on a mustang.
  8. Ecorse New Member
    Jan 3, 2009
    Message Count:
    Most circuits in the Mustang go through the 'Smart Junction Box'. Which means the horn button only sends a pulse to the SJB which will in turn switch on the horn relay. What this means is that it may be easier to switch the output of the relay (hot wire on the original horn) than to try to wire under the dash or at the SJB. You should be able to use a SPDT (single pole, double throw) toggle switch to direct the power to whichever horn you prefer. The switch has 3 terminals. Disconnect the wire from the original horn and connect to the center terminal of the switch. Run one wire from the original horn to either of the remaining switch terminals. Run another wire from the train horn to the remaining terminal. To locate the switch inside the car you obviously have to lengthen these wires and route them to wherever you locate the switch. This should allow you to select either horn with a flip of the switch. The only problem I foresee is if your train horns pull a lot more current than the original horns. If this is the case you may have to add an additional relay to the circuit. A higher current could burn out the contacts on the factory horn relay so check the horns current ratings. Burning out a horn relay isn't fatal but could be expensive to replace at your friendly neighborhood Ford store. Good Luck! :D
    Dave T.
  9. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    :hail2::hail2::hail2: Thank you for your valuable time!
  10. Ecorse New Member
    Jan 3, 2009
    Message Count:
    My Pleasure! By the way, my 2007 shop manual shows the factory horn wire that you are looking for to be YL/LG (Yellow with a Light Green Stripe). The black wire at the horn is a ground.
    Dave T. :flag:
  11. TBrad New Member
    Feb 15, 2009
    Message Count:
    91
    Here's the wiring diagram on the horn system for you to print out.
    It's pretty much self explanatory.
    Ford Service Manuals S197 - Horn Systems Wiring Diagrams
    ps TRAIN HORNS ARE GAY.
    I've seen on more than one occasion a few people just about get their ass kicked just for blowing their train horn at the wrong time.
    Anyhow good luck with that. :)
  12. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    LOL. I know but I have an extra set now and plenty of idiots that can't drive in the city I live in so I figured, if the shoe fits....
    and for those that want to fight, well I will just make sure I carry my Chuck Norris tee shirt with me at all times. :D
  13. One2One New Member
    Jul 14, 2009
    Message Count:
    18
    i didnt want to fight i just expressed my opinion in a dumb way so sorry for that hehehe.. hope we are ok :eek:
  14. MATRIX4.6 New Member
    Nov 26, 2005
    Message Count:
    120
    One2One, I have already called in a favor with Mr. Norris. It is imperitative that when he arrives that you tell him you want to buy a Total Gym before his roundhouse brings down your house!
Share This Page
