Front seat side air bags
Discussion in '2005 - 2009 Specific Tech' started by Cary Ford, May 8, 2007.
  1. Cary Ford New Member
    May 6, 2007
    Message Count:
    10
    Anyone have these installed at dealer? Is that something that can be done, or does it need to be done at factory?
  2. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    needs to be done when building the car. not a dealer add on accessory, soory.
  3. ARTTII New Member
    Jan 13, 2004
    Message Count:
    272
    Side air bag option becomes standard for 2008 model, maybe you can trade up :D
  4. cowtown Founding Member
    Nov 4, 2001
    Message Count:
    228
    Might be able to retro fit in some SAB equipped seats, as long as the wiring was all there.
    There might be some programming changes in the CPU though to let it know the bags are there. Not sure thought, just a guess.
  5. 67&05STANGS New Member
    Apr 4, 2005
    Message Count:
    54
    It's a little more complicated than just retrofitting seats. There are crash sensors that tell the bags to go off in a side crash and not to go off in a frontal or rear impact.
  6. cowtown Founding Member
    Nov 4, 2001
    Message Count:
    228
  7. gtss New Member
    May 1, 2002
    Message Count:
    125
    I would be shocked if anyone really would do it as a retrofit, primarily because of potential liability issues.
    in the event of an accident, if something were to go wrong the implications could be huge,
    I know I would not do it
    gtss
  8. french2812 New Member
    Oct 12, 2006
    Message Count:
    91
    I'm sure it can be done, and if done by a dealer there should be no liability issues. Big issue though is the cost. Much more than than buying it as an option.
  9. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    i would be that you will never find a dealer that would touch it. no matter who did the work, ther would always be liability if something went wrong. even the best tech can make a mistake, and it they did not operate correctly and someone was injured or worse the dealer wont be owning a dealership much longer.
Share This Page
