Fuel Delivery
Discussion in '94-95 Tech' started by tderrick, Oct 30, 2009.
  1. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    Looking ahead a little on my rebuild...
    If I go TFS kit , would I put 24# injectors in??
    Would the stocker pump keep up??
  2. greengoblin95 New Member
    Sep 30, 2009
    Message Count:
    94
    you could and as long as you stay n/a your pump will keep up, but it wouldnt hurt to upgrade the fuel pump later on. 19's could possibly still maintain, but it would be easier and without a doubt with the 24's, make sure you have the right meter for the injectors
  3. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    I will be staying NA...
    seeing as the injectors are 15 years old, I would be replacing them anyway.
    Would I need I tuner chip if I go with the 24s??
    And what / where is the meter?? Is that the fuel regulator??
    I guess it all depends on if I go with the TFS kit or just just spruce up the stocker stuff...
  4. frcefedlx New Member
    Dec 6, 2004
    Message Count:
    216
    The mass air meter is what greengoblin95 is refering to. So If you do run 24's make sure you get a meter calibrated for that. Also a tune would not hurt. your computer probably won't like the stage 1 cam and any issues from that could be taken care of.
  5. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    The OEM pump is tiny :Word:
    therefore
    You need to upgrade :)
    While a 110 lph will do the job ... I'd just do a 255 unit :nice:
    If you do aftermarket h/c/i and ALL supporting parts :banana:
    You will push 24's to the limit at stock pressure
    Again ... notice the words ... Stock Pressure :D
    If you are gonna tune it
    and
    With a combo such as this ... you should ;)
    You need to decide if you are gonna run OEM pressure
    or
    Go with an afpr and run elevated pressures
    My beliefe is to do it like Ford did it from the factory
    Run the stock OEM pressure and if doing that ........
    I'd run 30's
    If you go this route ... save the money as afpr is not needed :spot:
    Grady
  6. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    afpr = aftermarket fuel pressure regulator I take it??
  7. 302GTS If you need herpes, I'm your man!
    Apr 20, 2009
    Message Count:
    582
    Adjustable. :nice:
    Now, you asked if a tune was necessary. Your car will run on the stock tune and all, but it won't run to its fullest potential, and may have some idle/air/fuel issues down the road. I don't know about your area, but around here the most reputable tuners charge $400-$500 for a tune, and it's more than worth it. :nice: Grady was dead on about the fuel info too... I believe FRPP still has a deal where they're selling a 90mm Lightning MAF along with a set of, I believe, 36# injectors?? That could be something to look into.
    Keep us all posted! I'm sure you'll love this build when it's done. :nice:
  8. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    I hosed a bit with my info given above :bang:
    I said 110 lph and should have listed the pump size as 190 lph :)
    Grady
  9. 302GTS If you need herpes, I'm your man!
    Apr 20, 2009
    Message Count:
    582
    Who needs anything under 255, anyway? :D
  10. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    Hey, Grady... Starting to read peoples sigs to get some ideas. How are you running a stock MAF with your 30 #ers... :shrug:
  11. greengoblin95 New Member
    Sep 30, 2009
    Message Count:
    94
    he tuned his computer. you could use the stock meter, but the tune will increase the voltage to the two wires that are in the maf to get more accurate readings for the air/fuel mixture
  12. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    I think I'm starting to get a glimpse of the "Big Picture" :D
  13. greengoblin95 New Member
    Sep 30, 2009
    Message Count:
    94
    as you can see, a tune is always needed for any mod to gain better numbers
  14. Black95GTS New Member
    Jan 8, 2004
    Message Count:
    1,658
    Actually, your car will run like complete crap after doing that kit and not tuning it. Total a**. I would not run 36 pound injectors on this car as you would have a bear trying to finagle the duty cycle of a too-large injector. 30s are perfect for this combo as was mentioned by Dr. Grady.
    Who is...:rolleyes:
    Really smart. And posts like...:D
    William Shatner talked on Star Trek.:flag:
    The stock MAF is not "calibrated" for any size injector. The stock MAF is simply a device that uses resistive elements to transmit a voltage to the computer, 0-5V, corresponding to the amount of air flow that hits the elements in the meter. The same meter is used in both the GT and the Cobra, yet the tune in the processor is different for each car. The tune is what tells the computer how to process the data. The stock MAF is physically limited, in that it can only measure up to the air flow corresponding to around 350 fly wheel horse power.
    Example: If the tune is for your 19# injectors, but you have upgraded to 24# injectors, the computer will have the injectors open AS IF they were 19# injectors. So in that instance, you will run RICH, because the computer thinks you need to utilize your 19lb injectors at say 80%, when in reality you have upgraded and you should be only running at 60%. The computer does not KNOW what size injectors you have, you have to tell it via the tune.
    To complicate things, your car will attempt to adapt to the new A/F ratio, which further FUBARs your vehicle.
    So in conclusion, 24s will work but will be stressed out, 30s are ideal, and yes you definitely need a tune.
    Adam
Share This Page
