fuel filter
Discussion in '94-04 V6 Mustang' started by war69, Oct 26, 2006.
  1. war69 New Member
    Jan 11, 2004
    Message Count:
    91
    Wisconsin
    Hay whats the trick to getting the fuel filter off. clips are off do i just pull. its an 2002 gt thanks
  2. ChingonStang Member
    Sep 19, 2004
    Message Count:
    867
    Dallas, Tejas
    Clamp the lines as I believe the fuel is under pressure.
  3. AP1995V6 New Member
    Jul 14, 2003
    Message Count:
    561
    Oxford, MS
    there's a fuel kill switch in the truck. unplug it and turn the car over and it will die... this will empy most of the fuel out of the lines. on the casing around the fuel filter, there are some tabs that hold the filter in place... just bend them back. It's a fairly snug fit... just tweak the casing alittle until you're able to slide out the filter.
  4. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    Ripley, Ohio
    you need a special tool, you can buy it for 3-4 dollars from autozone, and it works on both fuel lines and A/C lines. The clips only secure it, however it is locked on internally and the tool releases it
  5. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Raleigh, NC
    IF you don't have the tool, you can slice a piece of a plastic lid or something similar (eg spray paint can lid) with a thin, flexible cylindrical shape and slide them underneath the lines that hook onto the filter to disengage the locking tabs.
  6. 02ponypackage New Member
    Apr 7, 2005
    Message Count:
    128
    Florida
    on average how long does it take to install a new fuel filter...and how much do they run ?
  7. AP1995V6 New Member
    Jul 14, 2003
    Message Count:
    561
    Oxford, MS
    Either the 95s are different that yours or you guys are talking about something else. In my experience a fuel line tool is not need to replace the fuel filter. The lines on the fuel filter are just held on by c-clamps and a fitted sleeve.
    Fuel filter is about $20, I think, and it should take about 5 minutes to change -- depending on how long it takes to get the car in the air, and all you need is a flat head screw driver.
  8. 02ponypackage New Member
    Apr 7, 2005
    Message Count:
    128
    Florida
    good....cause i would hate to pay 80$ at the dealership...i rather do things myself as i always do...i just dont bother with the oil changin because i rather not make a mess on the driveway or w.e
  9. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Raleigh, NC
    You can get them for $15 or less. '99+ stangs have some kind of locking mechanism where you need the tool or some kind of round skinny plastic like I used to get the lines to unlock.
  10. 02ponypackage New Member
    Apr 7, 2005
    Message Count:
    128
    Florida
    would advance auto no exactly what i need ? or where could i get the fuel filter if not there
  11. ChingonStang Member
    Sep 19, 2004
    Message Count:
    867
    Dallas, Tejas
    $80? The Ford dealership where I get my oil changed changes my fuel filter every few months and it only runs like $22.
  12. AP1995V6 New Member
    Jul 14, 2003
    Message Count:
    561
    Oxford, MS
    As far as I know, fuel filters aren't available through several of the parts stores. I had to get mine from a Ford dealer out of town since it was the only place that had them in stock.
  13. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Raleigh, NC
    Yes they should stock both a Motorcraft and a Purolator brand, with the Motorcraft costing a few cents less.
  14. 02ponypackage New Member
    Apr 7, 2005
    Message Count:
    128
    Florida
    Well Florida has a bunch of crooks out here....the rob every1....good thing my dads been working on cars since he was young because so much money would be waisted on simple S hit if he didnt teach me how to do things.............but neways i gota head out now for some brake pads and fuel filter.......got some new rotors coming in so i figure change everything at once......
  15. 02ponypackage New Member
    Apr 7, 2005
    Message Count:
    128
    Florida
    by the way how do u guys get the pics under your name ?
  16. Adverse2Change New Member
    Aug 21, 2003
    Message Count:
    351
    Raleigh, NC
    User CP at the top, then edit Avatar
Share This Page
