fuel filter?
Discussion in '2005 - 2009 Specific Tech' started by MI95Cobra, Jun 5, 2008.
  1. MI95Cobra New Member
    Aug 20, 2006
    Message Count:
    459
    i noticed that lately when i start up and take off the car feels lacking in power and kinda hesitates in first..... i'm thinking it might be the fuel filter..... where is it located and how hard would it be to change it out???? also i heard on the news that gas stations locally are reported of "watering" down the gas because of the prices.... could that be it??? let me know what you think....
  2. Riverart Active Member
    Oct 30, 2007
    Message Count:
    100
    28
    I changed my filter a couple of months ago...wasn't too hard but there is a plastic shield you have to noodle with to get to it.
    As for the watering down of the gas...man. that would be bad.
  3. Art161 Member
    Sep 26, 2006
    Message Count:
    131
    I think that if you had significant water in the fuel, the engine would stall. But it wouldn't hurt to add a bottle or two of water remover & fuel system antifreeze. The type with ISOPROPYL alcohol is the best.
  4. MI95Cobra New Member
    Aug 20, 2006
    Message Count:
    459
    cool, thanks guys....but not sure if water but the news said some kind of alcohol is being used which thins it down(?) and basically waters it down....if that makes any sense....
  5. V8JamesGT New Member
    Jan 22, 2006
    Message Count:
    215
    Not to hijack the thread. But are all fuel filters for our cars pretty much the same? I am close to 30k miles and was going to replace mine soon.
  6. Rubrignitz New Member
    Dec 11, 2007
    Message Count:
    SUPER easy to swap out the f/f on these cars. Look under the car directly under the driver door. You'll see the fuel lines running in/out and a plastic cover. Remove the cover and the filter has quick release clamps. I'd recommend depressurizing the system first as I had quite a bit of gas squirt out.
    I changed mine at 15k and will every 15k thereafter.
    howto:
    http://www.mustangforums.com/m_3713378/tm.htm
  7. MI95Cobra New Member
    Aug 20, 2006
    Message Count:
    459
    cool.....then what is what i need to do also....
  8. The Fang Member
    Sep 11, 2005
    Message Count:
    619
    The clips you only have to slightly squeeze the clip then pull apart. :)
  9. MI95Cobra New Member
    Aug 20, 2006
    Message Count:
    459
    done....it was really easy......the clips were simple....took me about 20 mins.....
  10. whyask New Member
    Apr 4, 2005
    Message Count:
    766
    yeh super easy I paid ford the first time 60 bucks and sat there and watched them, ( man what a waste of cash) If I knew it was that easy.. LOL, just did it again at my 20,xxx and it took 15 min.
  11. V8JamesGT New Member
    Jan 22, 2006
    Message Count:
    215
    Where can you get the fuel filter for our cars?
  12. MI95Cobra New Member
    Aug 20, 2006
    Message Count:
    459
    i got mine at autozone.....$8.50 after taxes.....
Share This Page
