Fuel float/ gas guage issue
Discussion in 'SVT Forum' started by GToddyT5, Dec 28, 2007.
  1. GToddyT5 Founding Member
    Jan 15, 2002
    Message Count:
    580
    Hamilton, NJ
    I replaced my entire fuel sending unit (stock replacement) over the summer and the gas guage has read incorrectly ever since. The minimum it will read is a little bit greater than a quarter of a tank. Can I fix this without dropping the tank again? I don't want to take those fuel lines off again...annoying as hell.
  2. cobradude New Member
    Sep 25, 2007
    Message Count:
    Maryland
    If your gauge was accurate before, I would say you will need to remove the sender again. It sounds like maybe the float is not travelling all the way. May be rubbing the side of the tank? Possibly you got the wrong part and is not compatible with the original gauge.
  3. wythors Get off my lawn!!!
    May 17, 2000
    Message Count:
    2,517
    28
    68
    C Addle
    Go to Sears and spend ten bucks on a fuel line disconnect set. It makes unhooking the lines a breeze.
    And yes, you will need to drop the tank again to fix whatever's wrong.
  4. GToddyT5 Founding Member
    Jan 15, 2002
    Message Count:
    580
    Hamilton, NJ
    I was using a Snap-On disconnect set the first time and it still took us a good amount of time. The tool that I had picked up from Advance didn't fit at all. OK, only way is to drop the tank again...got it. That's what I figured.
Share This Page
