ok well....i got my 255LPH pump and new sender in....car cranks....no hot to the F/P. I have a constant hot to the relay under the seat....and if you branch it from the green wire to the pink the F/P will kick on no problem...but im just not geting a exciter wire coming in to kick the relay open...all fuses apear to be good...I also check the upset switch in the trunk....we are at a loss at this point everything worked awesome last fall when the motor was pulled. Any ideas...
P.S this is a 90 LX 4-banger.
