Gas Mileage Question ?
Discussion in 'V6 Talk' started by IslandBlueStang, Dec 23, 2004.
  1. IslandBlueStang New Member
    Apr 20, 2004
    Message Count:
    24
    I have a 2002 Stang and I was getting about 450km per tank, and all of a sudden I am getting like 350km. Is such a drop just because of regular maintance (like I should change my plugs) or is it something more severe.
    A second question is, are there any wire kits you can buy for this engine like performance wires?
    Thanks Guys, any suggestions is helpful
  2. '03 6-Speed New Member
    May 23, 2003
    Message Count:
    233
    too many factors can play into this, here's a few:
    Make sure your tire pressures are all at factory specs
    Check your driving habits
    Get an alignment
    Are you carrying any more cargo than you used to
    be sure all your fluids are changed regularly
    Depending on miles, which you've got an 02 so you shouldn't need to, but new spark plug wires could help, but since you're not running high horsepower, you can just replace them with any parts store has as a replacement instead of high dollar plugs.
  3. doc4444 Founding Member
    Jul 11, 2002
    Message Count:
    235
    IslandBlueStang:
    This recently happened to me. Get a new fuel filter and or check your plugs/wires. IRT your question about performance wires there are all types out there, with 8.8mm? being very common. MSD, Bosch, Accel are a few brand names. Good luck.
  4. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Check your MAF and TB for crud and clean it out. Throw some Fuel Injector cleaner into the gas tank. Change air filter out for a K&N or equivalent.
Share This Page
