Gasoline
Discussion in 'V6 Talk' started by MidnightThunder, Mar 18, 2004.
  1. MidnightThunder New Member
    Feb 23, 2004
    Message Count:
    42
    North Ridgeville,Ohio
    What octane gasoline should I run in my car.I have a 3.8L v6 engine.
  2. 5-SpeedStallion Founding Member
    Mar 28, 2002
    Message Count:
    238
    Tampa, FL
    It's made to run 87. At least the newer one's are.
  3. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    West Texas
    depends if its stock or not and if its SC/Turbo charged.
    Now on a stock motor like yours it shouldn't be more than 9:5.1 compression so just use 87 oct fuel. If you incresse the compression more than 9:5.1 or add boost to incresse compression you will need to run 91-93 oct fuel.
    ***Now I've had a motor and see some that has for some reason ran a whole lot better on 89-91 oct gas when they was made for 87 oct gas. So if you car runs like crap on 87 try 89 and see what it does. You would be wasting your time and WAY more money by using 91-93 on a motor not made for it. Just to give you a heads up and I hope that helps.***
  4. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    gas
    I would run 87 octane. Run the lowest octane you can
    without detonation/pinging.The highest octane I would
    run is 89 octane.
  5. The Communist New Member
    Mar 3, 2004
    Message Count:
    12
    The graveyard of tomorrow
    The world needs to switch to alternative energy sources. Dino fuel was uncool a long time ago
    Petrol :nonono:
  6. ChrisYellowV6 New Member
    Dec 25, 2003
    Message Count:
    362
    Pensacola, FL
    87, but every now and then ill throw in a tank of 93 oct and run it on the interstate...cleans it out a bit.
  7. 5-SpeedStallion Founding Member
    Mar 28, 2002
    Message Count:
    238
    Tampa, FL
    What the heck??? :rolleyes:
  8. HyBriD-MorPhiS Founding Member
    Feb 26, 2002
    Message Count:
    615
    ST. Paul, MN.
    i dont use the stuff myself.. cost too much ;p
  9. ganador01 Founding Member
    Jan 22, 2002
    Message Count:
    1,597
    36
    Dallas/Fort Worth, Texas
    Actually it is the exact oposite. If you run 93 octane when you only need 87 you will get your combustion chamber dirtier, not cleaner. A higher octane gas has a higher combustion preassure so if the compression isn't there, then some of it goes underburned and could leave deposits on your valves. Running a 2 higher octane can be better just because the quality of gas could be better. I stress "could" not will. Btw, for all of you who are stuck in the whole brand name gas ideal, I'm going to clue you in. One day go out to a gas sump and watch all the tankers that go in and get gas. You'll notice that shell, chevron, exxon, mobil, they all grab their gas out of the exact same tank. And if you follow the tanker all the way to the gas station, you will see that no additives are added between the sump and the ending station. So all this chevron with techron crap, and all the other companies bs additives are just that. The only thing that i could think of is that the additives were added to the entire sump. This means that every tanker that gets gas from there will get the good gas. So whether you get shell or chevron, it doesn't matter. Btw, im not sure about the cheapo brand gas. I think they have their own sump. Like kroger, wall mart, race track, and all the lower brands have their own sump seperate from the big name sump. But i'm not sure of this. They may get their gas from the same dang sump as everyone else. Who knows. I've only done minimal research on this topic. Once again, I have answered a question no one asked!
Share This Page
