gear ratios
Discussion in '2005 - 2012 (S-197) Mustang' started by herm25, Oct 31, 2009.
  1. herm25 New Member
    Aug 5, 2009
    Message Count:
    14
    russellville, AR
    :D--------------------------------------------------------------------------------
    ok, so i assumed my stang had 4:10 gears in it..... I know I know what happens when one AssUmes, anyway I looked at the sticker that comes on the window when u buy it, and it says that the axel ratio is 3:31 so is that the same thing as the gear ratio?
  2. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
    yes, you have 3.31s in the rear...
  3. herm25 New Member
    Aug 5, 2009
    Message Count:
    14
    russellville, AR
    thanks that is what i thought just had to double check though
  4. Casey4s New Member
    Sep 2, 2007
    Message Count:
    236
    Woodbridge, VA
    Why did you assume it was 4.10s? The 3.31s are standard in automatics and I think 3.53 in manuals.
  5. whyask New Member
    Apr 4, 2005
    Message Count:
    766
    Sacramento
    dear god you assumed they had 410's LOL GO GET you some 4:10's and youll POOP yourself !
  6. 08gt08 New Member
    Oct 21, 2009
    Message Count:
    South Jersey
    i have a 08 gt 5-speed and it came with 3.31 in it
  7. herm25 New Member
    Aug 5, 2009
    Message Count:
    14
    russellville, AR
    i have an 09 5-speed, i never have figured out how gear ratios work i thought the lower the the number the better, cause that number tells you how many times the drive shaft spins before the tires do, so i figured lower was better, for some reason i thought 4.10 was standard and everyone was swapping to 3.73 and 3.53 lol.... i obvisouly misunderstood what i read.
  8. echoinsilence New Member
    Jul 22, 2009
    Message Count:
    87
    denham springs, LA
    its 3.55 actually and it all depends on what you're doing with your car, if you have a turbo setup then a higher gear ratio like a 3.55 or 3.73 will actually be more beneficial and help you build boost faster because it puts more load on the motor. but for N/A setups you want a lower gear like a 4.10 or 4.30 and if you really want to get serious even a 4.56
  9. BLKNED Member
    Jan 27, 2008
    Message Count:
    67
    He has 3.31's, those are standard in all GT's since at least '08. And that's what his sticker says.
  10. echoinsilence New Member
    Jul 22, 2009
    Message Count:
    87
    denham springs, LA
    I know he has 3.31's I was just sayin that the other gear is a 3.55 not a 3.53 and I'm pretty sure it depends whether it's an auto or stick as to which gear you get. I could be wrong though
  11. Ken04 New Member
    May 24, 2007
    Message Count:
    246
    Vancouver Washington
    me too, 05 GT manual.
  12. ct07gt Member
    Feb 15, 2008
    Message Count:
    355
    3.31 is standard for auto and manual, 3.55 was optional on the manual. I think it was a $155 option on my car, which is an 07. The GT500 has a 3.31, I think the Shelby GT and the Bullit might have had 3.73. Not sure on the last two.
  13. BLKNED Member
    Jan 27, 2008
    Message Count:
    67
    Ahh, got ya. The 3.55's were a $300 option when I ordered mine witch was late in the '08 model year.
  14. j_lutter31 Member
    Apr 8, 2008
    Message Count:
    113
    18
    Central South Dakota
    Ok, pretend your car has a 1:1 gear, it could go really fast but it would take a while to get there. As you increase your gear ratio, your tires spin slower with respect driveshaft, this increases acceleration, but decreases your top speed, (hence it increases your speed at any given rpm, that's why some people complain about gas mileage with 4.10's)
Share This Page
