Gears or Lower control arms
Discussion in '2005 - 2009 Specific Tech' started by baylor2010, May 1, 2006.
  1. baylor2010 New Member
    Apr 24, 2006
    Message Count:
    73
    I have a 06 gt (auto) with a C&L intake and diablo programmer, im debating wether to get gears or lower control arms next. What have yall experienced?
    thanx:SNSign:
  2. SilverBossGT New Member
    Apr 30, 2006
    Message Count:
    Alabama
    Have you been to the track yet?
    Do you have problems hooking the tires?
    If no problems hooking, then maybe you would want gears for better e.t.
    If you have problems hooking up, then maybe lca's and uca's at the same time.
  3. propellerhead New Member
    Apr 14, 2004
    Message Count:
    1,593
    "but what's with the but shots?"
    Gears will get you a bigger gain.
  4. Szlachcic New Member
    Mar 31, 2005
    Message Count:
    174
    Raleigh, NC
    Gears would be more fun, but they won't help you much in the way of e.t.'s if you can't get any traction. I vote for the control arms. You can have all the power in the world, but if you can't get it to the ground then it will do you no good.
  5. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
  6. baylor2010 New Member
    Apr 24, 2006
    Message Count:
    73
    I think im gonna go with lower control arms to stop wheel hop any ideas besides steeda ( I dont want to just buy their name because their big $$$$) that you have had experience with?
  7. V8JamesGT Member
    Jan 22, 2006
    Message Count:
    219
    18
    Wouldn't it be better (and cheaper) to get the Upper Control Arm over the Lower Control Arms because it'll stop wheel hop and allow you to set your pinion angle?
  8. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    7200 feet
  9. SilverBossGT New Member
    Apr 30, 2006
    Message Count:
    Alabama
    Have heard many good things about BMR.
  10. Fast05 New Member
    Sep 17, 2005
    Message Count:
    409
    Corpus Christi, TX
    LCAs
    I have both, gears and LCAs...I did the gears first, although I had bad wheel hop almost from day one. I ordered BMR lcas and they came in and i tore everything apart on my car needed for the installation only to find out that the bushings were too small :Damnit: So I returned them and purchased a set of motoblue billet lcas and they fit like a beauty, and absolutely NO wheel hop, I am very satisfied. :hail2: So I guess to answer your question, go with the lcas first, they are easy to install, only takes about an hour, and are relatively affordable (if money is a factor), and my launches are MUCH better.
    :SNSign:
  11. mongoose101 New Member
    Nov 5, 2004
    Message Count:
    24
    I have BMRs and 4;10 an am pleased but will be more pleased when I learn how to launch correctly every time.
Share This Page
