Getting rid of mach 460
Discussion in 'Mustang Sound & Shine All' started by SunburstGoldGT, Apr 3, 2005.
  1. SunburstGoldGT New Member
    Dec 18, 2003
    Message Count:
    139
    Blacksburg, VA
    My car is a 2000 GT with the mach 460 sound system, i replaced the head units about a month after i got the car now i want to remove the rest of it. I want to take out the rear box under the back window that holds the amps and speakers and also run the front tweeters, door speakers, and rear speakers off the head unit without having the harness's i have now. First question is after i take out the rear box, will a 6x9 fit in the hole under the grills in the rear decklid? What is in the cars without the mach 460? Second question is since i only have four speaker outs on my pioneer head unit how would i go about wiring up the front 4 speakers? I will have a total of 6 speakers 2 tweets, 2 front doors, and 2 rear 6x9's if they fit. I want to get rid of the rear box so my sub box could tuck up under the rear deck more and i could have my trunk back again. Thanks for any info.
  2. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    When you replace the front set of speakers, you need to replace it with a component set , that is tweeters in the little pod near the mirror and midrange speakers in the door. Then that one set of speakers (1 tweet+1 mid in the door) will work as one speaker. So your 4 sets of wires from the head unit will be fine. Hope that makes sense...
  3. Stangfanatic98 New Member
    Mar 31, 2005
    Message Count:
    148
    Woodbridge, VA
    I really would like to put tweeters in my stang. My 98' vert only has the stock basic audio system. Could i fit a system in with tweeters, other than OR including the Mach460. I plan on getting an Alpine CDA-9833 HU.
  4. MyEarsHurt New Member
    May 21, 2004
    Message Count:
    926
    You could get a set of kickpanels that house a component system. The kickpanels are way down near your feet, you can find them here... www.50resto.com or here www.sounddomain.com
  5. SunburstGoldGT New Member
    Dec 18, 2003
    Message Count:
    139
    Blacksburg, VA
    thanks and yes that makes sense, now where can i get a good set of components for my front? crutchfield seems a little over priced to me.
Share This Page
