subzero05 said:Who's Are They?
Redfire 05 said:I've seen posts on other forums saying they go in without modifications, but I don't think anyone has tried yet. Let us know how long it takes. Also post the results if your planning on dynoing it before and after. I'm really intrested, because these are the ones I'm planning on getting too.
It took me all of 8 Hours. I did not take the steering column out even the the instructions said too. I took my sweet time as I was not in any hurry at all. I gusee if I rushed it I could have save a couple hours. I put them on in my garage on the floor (so no lift makes it tougher on the back & neck) For all people who are going to put them on make sure you have a very very tiny wratchet and a 5mm socket to get the studs out. and you will need a 13mm open ended stubby wrench. I did not have to take the motor mounts off or the starter.subzero05 said:so all seems well with these?..no hitting the steering column or anything else from engine vibration or ?
If the fit is that good and there are no issues as you claim I will order a set to replace the JBA's I decided not to install due to above issues I mentioned....thanks
royb said:There is plenty of room around the steering column. The passanger side is a little tight. I don't notice any vibrations (yet) I need to climb back underneath and re check everything but I think it's fine. I wish I would have seen the MAC's in person to compare quality. I bought the FRPP over MAC based on the design since the MAC does not have the long flang. I wish the welding was cleaner on the FRPP.
Meat496 said:Are these shortys smog legal.
I was wanting to go with the JBA shorties until I heard about the motor mount isue. So now Im looking for alternatives, but because I live in CA it has to be CARB approved.![]()
thanks,
Meat
shanedog said:Good to hear there seem to be no mechanical issues....could you tell us a little about the performance and sound they produce?
Thanks![]()
royb said:Yes they are smog legal but I'm not sure if they are specficially CARB approved. The drivers side has the tap for the O2 sensor and I switched it over no problem.
Meat496 said:Thanks thats good to here.![]()
