Grinding noise when i shift into reverse.
Discussion in '2.3L (N/A & Turbo)' started by jstang209, Jul 8, 2004.
  1. jstang209 New Member
    Jun 4, 2004
    Message Count:
    622
    Hey.. this is my first car and it a 5 speed.. so i dont know if im doing something wrong or not.. but almost everytime when i go to shift in reverse theres like a loud ass grinding noise and i have to ease the shifter in slowly for the grinding to slow down.. this is also with the clutch all the way down and my foot on the brake too.. so what am i doing wrong??? thanks
  2. My Black Beast Founding Member
    Jul 18, 2002
    Message Count:
    83
    My 5.0 does this with the tremec and I have heard of alot of other T5's doing that. I have to put it in 5th and then to reverse or it will grind. :( It actually will not even go into the gear until I go into 5th. I don't know, give that a try :shrug:
  3. BlackPony2000 New Member
    Jul 2, 2004
    Message Count:
    95
    same problem with my 2000 Gt witha T45... could be nothing or it could be the syncronizer needing to be replaced...
  4. Jugador New Member
    Aug 30, 2003
    Message Count:
    70
    no problem at all. T5's reverse isn't synchromesh so all you have to do is put it in 5th and then reverse (actually any gear will work, but 5th is right by reverse). no grind. g'day
    ps for those inquisitive minds, putting it in 5th will synchronize the transmission since reverse can't. once it's synchronized, this eliminates the grind.
  5. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,461
    88
    Or just push the clutch pedal in and wait 7 seconds.
  6. JamesBaumann New Member
    Nov 27, 2003
    Message Count:
    625
    Same thing happens in my car and my dad's truck. I don't really think it's too much of a problem, or atleast I hope it isn't. After a while I kind of just learned how to maneoveur it into reverse without it grinding, mind you, it still does every now and again. But, I wouldn't worry too much about it.
  7. Jugador New Member
    Aug 30, 2003
    Message Count:
    70
    once again, IT IS NOT A PROBLEM. T5 REVERSE IS NOT SYNCHROMESH. YOU HAVE TO EITHER WAIT FOR IT TO SLOW DOWN AND SYNCHRONIZE ITSELF (like crovax said) OR SYNCHRONIZE IT JOOSELF.
  8. MSM0075 New Member
    May 14, 2003
    Message Count:
    749
    jus slap it in 1st the 2nd and then put in reverse. same thing happens 2 me with all my stick cars.
  9. jstang209 New Member
    Jun 4, 2004
    Message Count:
    622
    oh ok cool..ill try that, thanks..
  10. Asha'man Founding Member
    Feb 6, 2002
    Message Count:
    1,917
    I drive a lot of cars at my job (lot tech) and I do the 5-R shuffle on all of them. :p Force of habit, I guess....T5 reverse isn't synchronized and it's straight cut, so it needs effort to go in and it whines. Just one of those odd things.
    Ash
  11. Lx89Stang05 Founding Member
    Oct 19, 2002
    Message Count:
    1,005
    straight cut huh.. thats why it wines in reverse, kinda like a vortec SC in a way lol
  12. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,461
    88
    It sounds kool too.
  13. Ray III New Member
    Feb 10, 2004
    Message Count:
    604
    not SYNCHRONIZED. "Synchromesh" is a trademark originally of Cadillac's and now of GM (since they wn Cadillac).
    There is nothing unusual about the T5. All manually shifted gearboxes with a nonsynchronized gearset will experience grinding and difficulty shifting into that gearset. On other similar transmissions Reverse is even worse, need we mention CHRYSLER and smashed up reverse gear teeth. On older tractors with nothing but straight cut slider gears in the entire gearbox, it takes a great deal of skill to shift smoothly while in motion.
    One way to lock in such a gear is to stop the transmission completely (in fact your only choice when changing output direction of rotation), which is what you are doing by shifting into 5th first with the car motionless (synchronized 5th gear stops the transmission without grinding). Some cars have a synchronized reverse so this is not necessary.
Share This Page
