GT500 Blower
Discussion in '2005 - 2009 Specific Tech' started by NastyStang113, Jan 6, 2009.
  1. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Does anyone have a GT500 blower on their 4.6? Any feedback? Any numbers? I'll be doing it and would like to see some numbers.
  2. ct07gt Member
    Feb 15, 2008
    Message Count:
    333
    I think it would take a custom intake manifold and all the plumbing to make it fit, I haven't heard of anyone doing it. I think it would probably be cheaper to buy the FRPP whipple setup.
  3. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    It's a lot cheaper in my scenario, which will be virtually nothing. The only investment will be time and a little money for possibly GT500 fuel pumps and gauges.
    It's going to be going on a TVS set-up, of course minus the blower.
  4. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
  5. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    isnt TVS the blower? :scratch: what do you mean "It's going to be going on a TVS set-up, of course minus the blower."??
  6. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    The blower units will be swapped. It'll be using the TVS hardware as far as plumbing, etc.
  7. HEAVYGT New Member
    Sep 14, 2006
    Message Count:
    243
    never heard of anyone doing this...just not going to happen.
  8. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Explain. If no one hasn't done it, doesn't mean it can't be done. :rlaugh:
  9. rugedraw New Member
    Oct 12, 2004
    Message Count:
    51
    I tried doing some research into this a while back when I first got my S197, but yielded little results. If you do make it work, please let us know. I know you can pick up those stock GT500 superchargers for dirt cheap. If you can find a way to get it to fit on the 4.6L, I know I'd be interested in hearing about it!
  10. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Well, you'll be seeing results in 1-2 months. :nice:
  11. jojomustang New Member
    Nov 21, 2006
    Message Count:
    Any luck?
    Was actually just doing some research into this myself and came across this thread. Any progress into getting a setup that will allow the gt500 supercharger to fit on the GT?
  12. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    Nasty has mentioned in other threads he is working on it right now. :shrug:
  13. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    931
    28
    blower
    JDM has a 4.6 intake for the GT500 Eaton 122. teamjdm.com I think
  14. DiMora New Member
    Dec 19, 2008
    Message Count:
    60
    You are talking about three separate things here, and it is confusing.
    1) The blower itself.
    2) You need an intake manifold.
    3) You need all the plumbing: Heat exchanger, coolant pump, fuel rails, new injectors, new plugs, new IPTS sensor on furl rail, etc.
    TVS means "Twin Vortices Series" which is the design of the lobes inside the blower. It is still a Roots type blower, but it has a little more twist to it like a screw type system has.
    You need ain intake manifold that fits on a 4.6L engine (unless you drop in a 5.4 like a GT500 has in it).
    The blower and the intake manifold need to be designed for one another - the intercooler must match the putput capability of the blower. A bigger, hotter blower needs a bigger intercooler.
    I do not believe you can just take a GT500 blower and intake manifold and drop it onto a 4.6, but I don't know.
  15. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    931
    28
    more
    I think that by the time you are done building it and trying to tune it would be cheaper to go buy a new 4.6 Whipple. Also, you would have to tone it down so much, because it was designed for a 5.4, that it would become inefficient.
  16. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    I have been and my car was just finished and has been tuned. It's a beast now !! Some things changed and as of right now I decided to go a different route. It's not because I can't, more along the lines of a better opportunity came up and I took it. So with that said, the car does not have a GT500 blower on it but it can be done, it can't be done cost effective unless you know a lot of people though.
    I'll be posting up a thread with pictures, graphs, etc in the next few days. I might even be at the NMRA race at Bradenton with the car. I just don't know if I can make it ... I've got a lot of little stuff to get done on the car.
    I don't think you understood what I was doing correctly. I was getting the complete Roush R2300 TVS kit and just not using the blower (headunit) in exchange for the GT500's Eaton M122. It can be done. The blower (headunit), like I said before, will have to be machined slightly for some changes but it can work.
  17. o0Dan0o Founding Member
    Feb 8, 2001
    Message Count:
    485
    as for the original question, you could probably just take the roushcharger numbers (380ish RWHP) and add 30-50HP for the bigger blower (M90 to M122), my guess would be in the 410 RWHP range with the stock pully.
  18. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    After my research I'd have to agree with you on that. :nice:
  19. stangzilla100 New Member
    Oct 20, 2008
    Message Count:
    106
    so what do you have on there instead of the eaton?
  20. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    I'm not saying anything until I have pictures. I know I'll be raped by everyone saying where are the pictures !?!?
Share This Page
