H-pipe rattle help
Discussion in '2005 - 2009 Specific Tech' started by DoublL, Oct 15, 2008.
  1. DoublL New Member
    Oct 11, 2007
    Message Count:
    24
    Ever since i installed the o/r h at 2400 rpm i get a terrible vibration and i cant figure out where its coming from. i crawled back under the car and loosened and re tightened the bolts but it still does it? any tricks to help reduce the vibration. its only at 2400 not below or above but its BAD! thanks alot for suggestions.
  2. Radman New Member
    Feb 5, 2007
    Message Count:
    115
    Texas
    I think you are hearing an exhaust drone that is a byproduct of your h pipes and flowmasters. Put the originalmufflers back on and see if it changes or goes away.
  3. DoublL New Member
    Oct 11, 2007
    Message Count:
    24
    I dont have the original mufflers unfortunately. It could be the drone but you can hear it right in the middle of the car like its metal to metal almost? oh well im used to it now i just thought there might be a quick fix.
  4. PoopDawg Autozone Junkie
    Jun 21, 2002
    Message Count:
    1,435
    38
    Orlando, FL
    What brand? Pypes? More then likely the noise is coming from the metal hangers not positioned right in the rubber hangers at the tranny mount. They usually are tweeked a little and hitting the metal casing of the rubber hanger.
  5. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Florida
    I agree. My buddy had this very problem with his Pypes O/R H but we were able to get it fixed.
  6. STANGmole Member
    Sep 15, 2008
    Message Count:
    244
    Portland, OR
    Have you checked your e-brake handle? Mine was vibrating horribly (and loudly) until I performed the MGW Dynomat "fix" to it and I would have sworn it was coming from under the car and/or the exhaust or shifter until I grabbed the plastic cover while driving and the sound immediately went away. ...Probably not the source of your problems but easy enough to check.
  7. DoublL New Member
    Oct 11, 2007
    Message Count:
    24
    Thanks alot guys.. ill check the ebrake but im pretty sure its the Hpipe. it didnt start doing it until i installed it. so if its the hangers did you just adjust them until you got them right or trim the excess off or what? i guess i could put some duct tape around the end of the hangers drive it and see if it still vibrates?
  8. DoublL New Member
    Oct 11, 2007
    Message Count:
    24
    Its the jegs hpipe btw. i didnt like how pypes went to the 4 pieces so i just went with jegs. it was cheaper and i got in in about a day and half.
Share This Page
